01-07-2012, 03:00 AM | #1 |
How do i shave my door handles
hey guys i have a couple questions on how to shave my door handles. Currently my truck has an alarm on it that opens the door lock. i was wondering what i need to buy in order for the door to "pop" open
All help will be appreciated |
01-07-2012, 10:17 AM | #2 |
Re: How do i shave my door handles
esner,
so you have bear claws installed? what brand and what brand alarm? You should be able to get a shaved door handle kit, that would include the selenoid which unlocks it, and a pusher selenoid that pushes it open. Or the one selenoid might be able to do both, I forget what they told me. I was looking into auto lock and I think I might buy mine from roadkillcustoms because I called them and they took the time to explain to me the best options to go. for the AD trucks, I would atleast go with the 15lbs or even 35lbs selenoids, but the price is significantly higher. it would be wise to get a manual release latch you can hide under the door incase you loose power, you can get in. check out this kit, comes with remotes and all you'd need to do both doors, minus the backup latch. This is assuming you installed the bear claws. http://www.roadkillenterprises.com/5...aved-door-kit/
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
