1970 GMC cab floor
I am in a pickle right now. I have a 1970 GMC 1/2 ton 2wd 8 foot bed pickup with rear leaf springs. I have had it for about a year and a half now and have been working on it regularly. I pulled the interior apart and got the cab off the frame a couple of weeks ago and found a lot of patch work and some not so great repair work on the floor. The rear cab crossmember is pushing in due to rust and will need replaced as well as the rear cab supports and the rocker panels. Is this too much metal work to attempt? I don't have a big welder. Just a gasless mig. Should I try to sell the cab and find one in better condition? Thoughts? Comments?
Lemme show you something!!
Re: 1970 GMC cab floor
Only you can answer the "too much work" question. Being up in the NE- it'll be a stretch to find a rust free cab locally, shipping from out west will probably be your best bet......an expensive proposition. If it were mine, I'd get a couple sticks of 1" square tubing and brace up the door jambs and cab walls (fore/aft and side/side). For about $500 you should be able to get a full floor pan, the corners, supports and rockers. Take your time and stitch it all together....the flux-core will work fine, it's just a little messier (spatter).
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Just get one of these. Make the metal repair alot easier.
![]() ![]() Posted via Mobile Device
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
1969 Custom 30 wrecker
Get the full floor shown above. I did one last summer and it went great! For the most part, the only welding you'll do is plug welding which is easier than falling off a log!
![]() This is the way to do it right the first time. It's alot more work in the dismantle/assembly as you'll have to remove the cab but worth it. See my wrecker build thread for some pics of my floor job: http://67-72chevytrucks.com/vboard/s...d.php?t=448256
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Was that floor pan from LMC?
I bought mine through a friend who sells replacement metal. Its made buy tri plus. I'd say it's the same as lmc, dont imagine too many places are stamping them.
Thanks for the help fellas. I am saving for a new floor pan.
I am a Referee of life.
You're in Maine.There are lots of vendors closer to you.No sense in paying for shipping from so far away.You could probably pick it up at Carlisle.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Do they have a website? Do you know of any other companies up here?
#10 | |
![]() Join Date: Feb 2001
Here is your LINK http://67-72chevytrucks.com/links/browselinks.php?c=2
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
anyone know if they have one of those full floors with a high hump, for a manual/4wd set up?
1970 GMC 4wd 350 |
They don't have a high hump version but it's easy enough to make the change. I did this to the new floor I bought.
See my wrecker build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=448256
