01-07-2012, 11:13 AM | #1 |
glove box emblem question
ok ordered a new glove box "chevrolet" emblem for my 68 c10..and i'm wondering how it is suppose to attach?
It has three studs on the back side of emblem which go into the three holes on glovebox front..but no nuts to hold it on...and on further inspection the studs go into front but cannot be accessed from other side....does it come apart so i can attach the studs somehow or do i use adhesive? just wondering the correct way...by the way the emblem was 25..and its cheap plastic..so if anyone has an orig i'd be interested..thx |
01-07-2012, 11:55 AM | #2 |
Re: glove box emblem question
There is a little clip (I know what they're called, but for the life of me the name is excaping me right now) that you push into the holes then push the emblem studs into the clips.
Swing by a body shop. They will have what you need. Otherwise, check LMC.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
01-07-2012, 11:58 AM | #3 |
Silicone glue works and it's a lot easier than messing with attaching hardware. Just break off the studs and sand the back of the emblem flat first.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
01-07-2012, 02:01 PM | #4 |
I believe they are called barrel nuts, check with a body shop. When i put the new one on my 68 i used double sided moulding adhesive tape. but i did leave the studs on the back of the emblem so i could install it in the correct location. It worked out ok for me. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed 1966 C-10 lwb,factory A/C,Custom Cab 1954 Delray 2-door sedan [rat rod project]
01-07-2012, 02:41 PM | #5 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-07-2012, 03:17 PM | #6 |
you guys are great..gona try to find barrel nuts..but wont i have to be able to get to the back side...there is like a cavity between front of glovebox and back and no way to get to stud to put on nut...
01-07-2012, 03:45 PM | #7 |
Moderator
the barrell clips push in from the front, you do not need to access the back as they do not screw into the studs.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-07-2012, 03:45 PM | #8 |
thx
01-08-2012, 10:02 AM | #9 |
Yeah,these aren't nuts at all. Just press fit,which makes removal the harder part. If you don't find these,silicone or weatherstip adhesive (my favorite) will work and there's no need to remove the studs.
01-09-2012, 07:12 PM | #10 |
Kevin,
Come over and I will show you how to do it and what to look for. I have mine off and can show you how when and where. I am here if you ever need any help my brother. R/ Billy
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
