Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-07-2012, 04:23 PM   #1
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
WTB - '87 Crew Cab Seat Belts
I know this is a shot in the dark, but I would like to see if anyone has anything laying around...Light Saddle (Tan) color and must be in good shape.
Don't point me to LMC, because their replacement seat belts are not correct for my truck. Their units are single retractable (only one for the shoulder with a fixed lap belt) and my seat belts have dual retractors (one for lap belt and one for the shoulder).
Thanks!
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 01-07-2012, 04:58 PM   #2
Jax87LS1
Re: WTB - '87 Crew Cab Seat Belts
i have an 87 single cab and i had stock tan interior i still have the seat belts and trim pieces
Jax87LS1 is offline   Reply With Quote
Old 01-07-2012, 05:00 PM   #3
Evil Trailblazer SS
Single Cabs are different than the crew cab.
The fronts out of the Suburban are the same as the crew cab and the rears from the Suburban are similar but missing an extension plate but I can take them anyway...
Thank you though!
Old 01-11-2012, 11:53 PM   #4
Devillusion
Devillusion's Avatar
I have a set, any chance you have a set of red ones in good shape?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 01-11-2012, 11:56 PM   #5
Evil Trailblazer SS
I do not have any red ones...I have a line on some good condition gray ones though.
Do you want to get me some photos of the set you have? Is it light saddle? Condition?
Old 01-12-2012, 01:22 AM   #6
Devillusion
I have a couple sets of grey ones, want to do my interior in lipstick red.
I'll have to dig them out, they were fine I think other than just needing a good cleaning. Were barely used I believe cause the truck was a farm truck and it is an 89.
1970 Chevelle
Old 01-12-2012, 01:31 AM   #7
Evil Trailblazer SS
Let me know when you can dig them out because I need to make sure the plastic covers for the retractors are all in good shape. I will re-dye them and get the belts themselves re-webbed in the right color.
Old 01-12-2012, 02:27 AM   #8
Devillusion
Why don't you just re-dye the grey ones then? wouldn't that be a hell of alot less hassle?
1970 Chevelle
Old 01-12-2012, 08:33 AM   #9
Evil Trailblazer SS
Yes it would be less hassle...unless yours are in better shape. Are yours out of a Suburban or a crew? The other problem is, one of the lastic covers may be missing for one of the rears...no good!
Old 01-13-2012, 02:14 AM   #10
joe231
joe231's Avatar
The rear 3 point belts in the crews are the same as a regular cab 3 point belt of the same years. They changed the shape and size sometime after 84.
CHEVY ONLY
Old 01-13-2012, 10:03 AM   #11
Evil Trailblazer SS
Well that's just it, I only have lap belts in the rear.
Old 01-13-2012, 12:18 PM   #12
joe231
joe231's Avatar
Oh
I see
I thought 87 had rear shoulder belts.
CHEVY ONLY
Old 01-13-2012, 05:06 PM   #13
kevinr1970
The fronts out of the Suburban are the same as the crew cab...
Are you sure about that?
I seem to remember buying a set out of a Suburban and they did not work, although it might have been the rears that were the problem?
This was about two years ago, so my recollection is fuzzy.
Originally Posted by joe231 View Post
Oh
I see
My '87 GMC crew has lap belts only also.
That is making it a pain to find some new ones for the back because I have tan on one side, and red on the other, but the rest of my interior is blue?
I remember someone saying* that the crews had the weld-nut under a push plug on the pillar for shoulder belts, but either my truck didn't have a hole to be plugged, or I pulled the plug out and there was no wled-nut?
My truck was a government stripped-down model so I assumed they made it as cheap as possible and that was why it wasn't there?
*I also remember someone saying the rear seats were a direct replacement from a regular cab to the rear of a crew, and while the seat probably is, the mounting brackets are not.
I didn't find that part out until I tossed my ratty seat hoping to replace it with my nice re-upolstered reg cab seat.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-13-2012, 06:54 PM   #14
joe231
joe231's Avatar
[quote=kevinr1970;5121005]Are you sure about that?
[quote/]
I am sure.
I have used front Burb belts in one of my crews. The rear belts could be used with a little modification. The rear crew and Regular cabs have an extra little angle bracket to make the assembly sit level on the angled floor.
Good to know.
Yeah seats are almost the same(front benches don't fold forward, I have used the fold mechanism from a regular cab seat to convert it) brackets aren't. You could use regular cab tracks in the rear by adding the rear holes and nuts under the floor, it would give adjustment of the seat but cut down on legroom. The rear brackets move the seat rearward, even less room for a sub box...
CHEVY ONLY
Old 01-13-2012, 07:01 PM   #15
gmech
Ive got tan front and rears from my 91 CC, I just need give them a good once over to see the condition.
gmech is offline   Reply With Quote
Old 01-13-2012, 11:09 PM   #16
Evil Trailblazer SS
Let me know ASAP! that would be great if the plastic covers are all in great condition! Even if the belts themselves need to be re-webbed with new material I will take them!
Old 01-15-2012, 11:14 PM   #17
gmech
After looking. I dont think the ones that I have would be up to par with what your looking for. Good luck.
Old 01-15-2012, 11:50 PM   #18
joe231
joe231's Avatar
Got pics?
CHEVY ONLY
Old 01-15-2012, 11:56 PM   #19
Evil Trailblazer SS
Yes, I would like pics too...
