Old 01-07-2012, 07:41 PM   #1
Tmend
Tmend's Avatar
Help please ASAP !!!
So I got a 5.3L out of a Chevy avalanche 2005. My question is what do I need to take off the truck to make this run later befor I send it to the scrapper. Also what swap would this be L6 Ls1 so on so I know what parts to by later thanks
Some progress is better then no progress
Tmend is online now   Reply With Quote
Old 01-07-2012, 07:53 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Help please ASAP !!!
I would take everything under the hood as far as electrical. PS hoses, Belts, Rad Hoses, exhaust Y pipe with the 4 O2 Sensors, air intake ducts and the fuse box. Wiring to the transmission,
dwcsr is offline   Reply With Quote
Old 01-07-2012, 08:03 PM   #3
Tmend
Tmend's Avatar
I got all that but what about ECM and also I heard some of these eng won't run if u don't have the cluster and gas pedal assembly
Old 01-07-2012, 08:19 PM   #4
truckdude239
truckdude239's Avatar
ecm you will need it will ahve to be reprogramed to have the paslock turned off and some other thing but there are many companys out there.
check out the faq section for the lsx swaps
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
and the section where everyone asks there questions theres alot of folks doing this swap so the info is here somewhere
http://67-72chevytrucks.com/vboard/f...play.php?f=206
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-07-2012, 11:08 PM   #5
mooseknuckles
mooseknuckles's Avatar
take everything that is connected to the motor/tranny by wires, hose, or cable....I'd scrap the donor after I was done the swap.
mooseknuckles is offline   Reply With Quote
Old 01-07-2012, 11:13 PM   #6
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I moved this to the LSx section for ya. Here is my "shopping list" for when I bought my engine and trans.
Engine with everything attached (alt, Power steering pump, Water pump, AC compressor, Fan, coils, throttle body, manifolds).
Radiator and any hoses.
Any coolers that are separate from the radiator (trans, oil, power steering) including lines +hoses.
If vacuum boost brakes check valve and grommet.
If it uses Hydro boost brakes(instead of vacuum), the entire hydro boost setup.
Trans with mount, mount bolts and drive shaft.
Starter with bolts.
Computer+harness+fuse box w/all battery cables.
Gas pedal+TAC+harness.
Exhaust Y pipe.
OBDII port+wiring
If vac boost check valve and gromet.
I still managed not to get the TAC(Throttle Actuator Controller)
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
