01-07-2012, 08:09 PM | #1 |
Steering question
I have a 66 and have the front suspension of mid 80's and want to keep my manual steering.I am going to rebuild and use from control arms out,want to know if I can use my factory pitman arm and connect to new steering setup?I know I will have to drill new holes to mount idler arm.Thanks for all the great tips and ideas.I will post pics as I progress.
01-08-2012, 01:32 AM | #2 |
60-66 Nut
Re: Steering question
You should be able to use your manual pitman arm on the later model draglink. I have used the power steering pitman arm on the original draglink, so it would seem that it should work the other way around.
