Roadtrip!
![]() Join Date: Feb 2003
Help with 4 bbl carb riser I.D.
Can we get a positive I.D. on these? (carb to air cleaner) Short one for a 4x4? Any help is appreciated.
Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Roadtrip!
Re: Help with 4 bbl carb riser I.D.
Someone must know the correct application of these. These are from 67-72s.
I never noticed any differences before this. I just checked my '71 C/30 and '72 K2500 and they are both the same...about 2 1/2" tall and both are small blocks. I have another one around from a '71 C/20 but pretty sure it will be the same. My guess would be maybe the short one is for big block(?) and maybe the tall one is a medium duty??
That's a good question. Every V8 4 barrel (sb, bb, 2wd,4wd, 1/2ton,3/4 ton) i have every seen used the same spacer.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Maybe the shorter one was for older BB (68-69) that had a high-rise intake?
I've always wondered what they're for except to provide clearance. I was talking with an old GM guy and he told me that the riser was for three reasons:
1) clearance for the linkages 2) prevents the carb from getting too hot by an air cleaner that sits so low it prevents cooling airflow around it 3) turns the intake airflow to hit the venturii straight down rather than allowing the air to "skip" across the top of the carb. All those reasons sound pretty good, but I was wondering how much truth is in them. When I put a riser on, I notice a slight loss in power causing me to push the gas pedal in a bit more to get the same results. So is it really more efficient? What do you guys think? |
Al those sound like good reasons. For linkage clearance the filter housing could have been designed to clear that w/o a spacer. So,it seems kind of silly. It does give a more direct breather location to help keep oil from puking up into the filter? They do act as a stack to bring a better volume of direct intake air into the venturi.
I'm not in front of my truck right now with a tape measure but I'd swear my 4x4 spacer is just like the middle one. Which looking at the tape measure is a lot like what special-K described in his post.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Both of my v8 4x4 trucks have the taller spacer, both are 72 if that helps or matters, they are also the same height as the spacers on my bb trucks as well
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
That tallest one doesn't have a breather port,does it? My instincts say bigger truck on that one,maybe older? Maybe tall deck? Were those even 4bbl?
Roadtrip!
Tim, no hole in the tallest one. That was my thought also was a bigger truck. I think the holley were mainly on tall decks.
I have a big block spacer here that is 2 1/2" has the arrestor in line with a metal pipe into the valve cover. My guess for the short ones was 4x4 since the engine sits farther back and it gets tighter to the firewall. sameyrasmea72, the theory on the big block sounds good. I will look at some others i have and see.
Who's got steelies?
![]() Join Date: Feb 2006
A tall spacer without a breather hole is what I am currently using with an air cleaner I pulled off a 68 1/2 ton with 327 at a salvage yard. Of course, there is no way of knowing if it was the original air cleaner or not, but it had a provision for the breather on the air cleaner itself. No damper door on the snout either.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#13 |
I didn't know they were different either but I think I may need one of those short ones....
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#14 |
Just like to part out trucks!!
I've had one of those shorter ones before WOW that sounds good doesn't it
![]() Anyway I think the shorter one was on a 68 BB I parted if I remember right but remember Eric, I do drink some so I may be wrong. I've never seen one of the bigger ones like that ![]()
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#15 | |
Seriously Randy, do you have an extra one of those? Jeff
#16 |
None right now Jeff, we will have to look for one at the Swap meet
