01-08-2012, 12:45 PM | #1 |
Trans removal or shifter removal
The shifter on my trans comes from the top of the trans. I either need to figure out a way to pull the actual shifter out or know the easiest way to pull the trans. Cleaning up the top a bit it looks like I may have to remove a full plate which looks like it may expose the top of the trans.
So what is the trick to remove the shifter? Do I need to remove the full top plate? |
01-08-2012, 01:27 PM | #2 |
Senior Enthusiast
Re: Trans removal or shifter removal
Here's an earlier thread on removing the shifter stick:
http://67-72chevytrucks.com/vboard/s...d+stick+remove And here's a different thread on transmission removal: http://67-72chevytrucks.com/vboard/s...hifter+removal |
01-08-2012, 06:16 PM | #3 |
Thanks,
your search skills are much better than mine apparently |
