Old 01-08-2012, 01:32 PM   #1
mooseknuckles
mooseknuckles's Avatar
sensor
there is a sensor of some kind located behind the throttle body on my 6.0 thats broke off, what is it?...searched but came up with f.a.
mooseknuckles is offline   Reply With Quote
Old 01-08-2012, 01:45 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: sensor
EGR, don't bother plugging it in, you'll remove it in your tune anyway. You can pull it out and replace it with a plug, or anything that won't leave a vacuum leak.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-08-2012, 01:56 PM   #3
mooseknuckles
Re: sensor
thanks.
Old 01-08-2012, 02:37 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: sensor
Actually its the EVAP solenoid, but still the same answer. Plug it and have your tuner turn off all the EVAP codes.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-08-2012, 10:16 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: sensor
^you are correct. I just pulled it out and threw it in the garbage either way
Old 01-08-2012, 10:19 PM   #6
mooseknuckles
Re: sensor
thanks...mines broke off so thats where it's goin.
Old 03-01-2012, 12:22 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: sensor
So what are people using to plug the EVAP/EGR hole?
Rich
1972 K5 Blazer CST Click HERE
Old 03-01-2012, 01:26 AM   #8
OldCreek
OldCreek's Avatar
Re: sensor
I left the evap in place and put a rubber nipple/cap over the tubing. It's all hidden under the cover anyways.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-01-2012, 10:01 AM   #9
usmcchevy
usmcchevy's Avatar
Re: sensor
X2, or if you're an oger like me and break the thing off a 1/4 NPT plug will screw in.
Build thread
LSx Swap FAQ index
