Old 01-08-2012, 02:06 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
A-arm clearance when running 15" wheels
How much do you have to grind off the control arm when you run a drop spindle (I've got Bell Techs) and stock 6" or 7" wide 15-inch stock steel wheel? A little or a lot?
Or...CAN you run a skinny front 15" steelie with dropped spindles? I'm going for a particular look on my '64, and I need to know what I have to do.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-08-2012, 02:39 PM   #2
nds1968
nds1968's Avatar
Re: A-arm clearance when running 15" wheels
I only had to grind a very little bit of the lip around the ball joint on my 72 C10 with bell tech spindles and 2" drop coils. I was running 15"x8" aluminum wheels though so you may be OK with the stock steel wheels.
I'm sure others will chime in.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
