Old 01-08-2012, 05:38 PM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Engine Help
Okay so here is my situation, my truck will not start when it is below 40 degrees. Once in a while I can get it turn over and idle for a minute at most and die. When it idles it idles rough and is hard to keep running. The engine is a 305 and I need help with this any help is useful thanks.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 01-08-2012, 05:41 PM   #2
irishman999
irishman999's Avatar
Re: Engine Help
Sounds like a choke problem, what carburetor do you have?
irishman999 is offline   Reply With Quote
Old 01-08-2012, 05:47 PM   #3
Car'n'Guitars
Re: Engine Help
Quadrajet, that's what I was starting to think too, but I didn't know because it was adjusting the choke on its own.
Old 01-09-2012, 05:54 PM   #4
Car'n'Guitars
Re: Engine Help
If it was a choke problem and I manually closed the choke to start it, theoretically it should start and run right?
Old 01-09-2012, 06:15 PM   #5
str8axle55
Re: Engine Help
If you have a helper, have them start the truck when it is cold, so you can watch the choke to see what it does. It should be open a little to let some air in to start it, then as it warms up the choke thermostat will open it the rest of the way. Is the choke working at all, any tension on it when cold? The choke pull off, also needs to be (A)hooked up and (B) hold vacuum. If you pull the vac line off of th choke pull off, and compress the rod, it should stay compressed with your finger over the hole.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 01-09-2012, 06:17 PM   #6
Car'n'Guitars
Re: Engine Help
I just did part of that we tried to start it and the choke did open a little bit like you said it should. It sounded as if it was on the verge of firing but then nothing.
