Old 01-08-2012, 06:34 PM   #1
Touchdown67
Touchdown67's Avatar
Valve cover breather leaks.....
I have a SBC 400 with MT valve covers. The problem I am having is the breather is leaking. I put a PCV valve on the left cover and plumbed it into the carb. What can I do to stop the other one from leaking oil out?
Touchdown67 is offline   Reply With Quote
Old 01-08-2012, 08:22 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Valve cover breather leaks.....
When you say left side I don`t see it I`m assuming you mean the right side, is the breather cap on the right solid with no holes...anwhere in it besides the PVC valve / line...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-09-2012, 01:30 AM   #3
Captainfab
60-66 Nut
Is the baffle plate in place on the inside?
Old 01-09-2012, 02:57 PM   #4
glos55
glos55's Avatar
I think he means left side of engine as if you were sitting inside. From the pic you can see where the oil is leaking and burning off on the exhaust manifold. I agree with Captainfab and check for baffle in valve cover.
glos55 is offline   Reply With Quote
Old 01-09-2012, 03:13 PM   #5
argonaut
argonaut's Avatar
Yeah, a good PCV valve and good baffling on the inside of the valve cover, below the breather port, should prevent this sort of thing.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-09-2012, 11:52 PM   #6
Touchdown67
I do not believe there was a baffle plate in either cover. That would probably make all the difference. Thanks.
By the way your P/S bracket worked perfectly.
