Old 01-08-2012, 07:05 PM   #1
eddie63
63 c10 dual master cylnder and brake line splitting question
So it's time for me to upgrade my old single master cylinder to a dual power brake mc. I have read the awesome ChiefRocka thread but still have a question or two. The brake line on the rear of my truck are 3/16 and the fronts are 1/4 . I see that there are adapters from 3/16 to 1/4 but what I am wondering is do I need to get some type of proporting vavle or is it ok to just use the adapter and run a 1/4 inch line from the adapter straight to the new mc? Any help and advice will be greatly appreciated. This is my first time posting.
Eddie
eddie63 is offline   Reply With Quote
Old 01-08-2012, 08:18 PM   #2
krazy_texan
krazy_texan's Avatar
Re: 63 c10 dual master cylnder and brake line splitting question
just run it with the adapter in line you should not need the proportioning valve unless you are going to disk brakes.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-08-2012, 08:39 PM   #3
eddie63
Re: 63 c10 dual master cylnder and brake line splitting questiont
I am keeping it drum/drum. Thanks for the answer!
Eddie
Old 01-09-2012, 01:33 AM   #4
Captainfab
60-66 Nut
For drum/drum brakes, no proportioning valve is needed. If you wanted to, you could run the metering block like they used on the '67-'70's, but it is not absolutely necessary.
Old 01-09-2012, 02:05 PM   #5
eddie63
Thanks Captainfab! I'll try it without the metering block and see how they work but at least I know now that its an option if they're not working right. Would the metering block prevent them from locking up?
Eddie
Old 01-10-2012, 12:14 AM   #6
'63GENIII
'63GENIII's Avatar
Hey Eddie. Welcome to the forum. I see you've already got some of the gurus on it so I'm just gonna follow the thread. You're going to really dig those brakes when you're done!
How bout some pics of that truck!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-10-2012, 02:36 AM   #7
eddie63
Thanks for the welcome and I have gotten some great advice from the gurus . I ll post some pics and probably more questions as I'm doin the work over the weekend.
Eddie
