Old 01-08-2012, 07:55 PM   #1
1987cherokee
1987 issues / Help Please
Im in the process of my first 87 swb re-build. 1st issue is with the engine. I put a Comp Cam (268) in an otherwise stock 350/ TBI set-up. Do I need a E-prom change ? Having idle issues.
2nd question.... Have located a rear end from a 1990 454ss. It is supposed to be a stock application 373 posi. What issues will I face trying to install into my 1987 ??
Thanks in advance for any help !!!!
1987cherokee is offline   Reply With Quote
Old 01-08-2012, 11:01 PM   #2
makman1297
makman1297's Avatar
Re: 1987 issues / Help Please
This should help with your cam selection. http://www.tbichips.com/truckmods.htm
The rear axle will have a different spring perch width and shock mount location, not a direct swap without welding/modification.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
