Old 04-25-2003, 09:20 AM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Steering Box Input Shaft Seal
My power steering box is leaking at the rag joint. How hard is it to replace the input shaft seal?
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 04-26-2003, 04:30 PM   #2
jhow66
jhow66's Avatar
Not to bad but been awhile since I did one. Just be careful putting the new seal in so as not to cut the seals edges on the splines. Make sure there are no burrs anywhere(learned this the hard way). Use some grease when installing. Looking at what you have done to the rest of the truck,you should have no trouble.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
