Old 01-08-2012, 11:30 PM   #1
shrike
shrike's Avatar
steering column questions
So, I'm in the middle of replacing my turn signal switch and I have a few questions.
Disclaimer: I know almost nothing about steering columns, so please excuse any ignorant questions.
1. I have the switch out, and the aluminum piece underneath it is just sitting in there loose.
Is that correct?
It looks as though the only thing holding it on is the 3 screws that hold the turn signal switch on.
2. The bearing in the middle of that aluminum piece has seen better days. Are replacements available?
3. The threads on the end of the splined shaft that the steering wheel is bolted to are kinda chewed up. Is it possible to replace that shaft short of taking out the whole steering column?
Thanks in advance for any advice!
Scott
1970 C10 Fleetside longbed
350/TH350
shrike is offline   Reply With Quote
Old 01-08-2012, 11:51 PM   #2
Bert W
Bert W's Avatar
Re: steering column questions
Without pics, I can only answer question number 2. Yes, the bearing can be replaced. I am speaking about the one that keeps the steering shaft centered in the column.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 01-09-2012, 02:44 AM   #3
shrike
shrike's Avatar
Here is a pic with the aluminum piece:
and one of the steering shaft:
Any idea where I can get a bearing? I looked at a couple of places online, but I'm not seeing anything listed.
Thanks!
350/TH350
Old 01-09-2012, 07:48 AM   #4
westgl
westgl's Avatar
You can either measure it with calipers, Or pull the bearing, and take it to a bearing shop.
Motion Industries, Maybe
Napa?
Westgl
westgl is offline   Reply With Quote
