Leaking pwr steering box
Hi has anybody done just the bottom seal on a 69 C10 pwr steering box , how involved ?? or best way to go about it ??
thanks Ray |
The Older Generation
Re: Leaking pwr steering box
All I did with mine is put some Lucas power steering treatment in it... No more leaks... LockDoc
this might be of use?
http://www.fourwheeler.com/techartic...ild/index.html not sure if same box as yours but its a good read anyway
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
#5 | |
thanks again Ray |
It's all in the timing
Ray,It may be possible to replace the seals on the bottom[sector shaft]while its in the truck but it would be difficult.You are going to have to get the front of the truck raised pretty high because you have to pry the old seals out and hammer the new ones in.Also you will have to remove the sector shaft out of the box in order to access the seals.I just got done rebuilding my entire box and I think it would be easier to just remove it.Just center the steering box,loosen the 4 bolts and it should slide out.You will also have to replace the top seal on the sector shaft cover.Heres a video that help me do it. http://www.mypowerblock.com/video/mu...steering-box-1
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
#7 | |
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
My PS box is leaking on my 87. I bought a rebuilt box, and took it to a shop. They will install it far $110.00.
Thanks for all the advice .. I bit the bullet ,1 hour and a $3 seal all done , I pulled the Steering box and did it on the bench , pried the bottom seal out punched the new one in jobs done know onto the next leak
