01-09-2012, 12:35 AM | #1 |
55-59 gauge question... using a temp or fuel for oil and volt
I did some searches and couldnt find out what I was looking for...
1st... I hate the idea of having an oil tube running into the cab, and besides that, my engine already has a elecronic oil sensor... so I was wondering what OHM readings the stock temp and fuel gauges (i think i already know the fuel is around 0-90) I was thinking about modifying the stock housing to adapt another temp or fuel gauge in the oil and amp slots... anyone try this? I just dont know what ohms my factory 1978 pontiac oil sender and volt meter used... I am thinking the volt just won't work, but i think i remember seeing someone rip apart a gauge and make an oil or volt gauge... anyways, if anyone has a thread of hacking into the stock gauges I would love to check it out!! |
01-09-2012, 06:15 PM | #2 |
Re: 55-59 gauge question... using a temp or fuel for oil and volt
i have no problem using the stock oil gauge, all vehicles had them for years.
i do have a problem running all the electrical load thru the dash amp gauge before sending it to the fuse block. i converted my stock amp gauge to a volt meter and did a write up on hotrodders.com. i re-did it and posted in this forum in my 58 TRUK intro thread using a little ingenuity and some moxie, i don't see why any gauge could not be converted this way.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-09-2012, 06:41 PM | #3 |
this is exactly what i was referring to! Thanks for your writeup!!
Because my harness has the wiring for the oil sensor as well, i may look into their gauges and see if they have a oil pressure as well. THANKS!!!!! -Jacob |
