Old 01-09-2012, 01:03 AM   #1
dougo
dougo's Avatar
need recommendation for brightest low beam headlight
I would like to swap out the low beam headlights on my GMC burb for the brightest lowbeam lights without changing the harness. trying to go this route before figuring out a light bar that i can take on/off for back county trips). dark nights are brutal....i cant see much. i searched the archives....did not see anything (no pun intended).
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 01-09-2012, 01:09 AM   #2
mud.man.rj
mud.man.rj's Avatar
Re: need recommendation for brightest low beam headlight
I bought HID's for my last truck a 79 Bronco, went HID for low beam only and standard 100watt for high beam, it all plugged in and no big deal, beautiful light and I never used high beam again. My 71 Gm is going to get them after I do a few other things. It came as a seal beam (diamond cut) and bulb kit and fit in as factory would. Think I paid around the $300 mark.
mud.man.rj is offline   Reply With Quote
Old 01-09-2012, 01:23 AM   #3
67swb72klb
67swb72klb's Avatar
u can get an h-4 conversion kit and also wire in a relay that will realy help u see the light
u can do asearch for the relay wireing diagram
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-09-2012, 01:24 AM   #4
Blue72slab
I highly recommend that you install relays to power your lights - it will make a HUGH difference. Use the wires that run to the lights now to switch the relays on so you can send 14V to the lamps from a full power source. I did that and put in halogen lamps and they look twice as bright.
Larry
1972 Chevy C20 Custom Camper
1968 Chevy Camaro RS
1980 GMC K5 Sierra Classic
Blue72slab is offline   Reply With Quote
Old 01-09-2012, 01:32 AM   #5
dougo
dougo's Avatar
thanks....good recommendations. i hope to do the swap before next road trip in feb to the high desert
Doug
Old 01-19-2012, 11:35 AM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I have Hella H4 conversions and relays on my 63 and they are nice and bright at night. I believe they also make a 5 3/4 version for 4 headlight setups.
Also, lights from a 90s BMW 7 series are projectors behind glass lenses that look nearly original. They call them e30 or e32. I ran a set on my donor dodge to pull my 68 home and rarely needed the high beams even in the middle of nowhere. Does take some work to fit them in, but this is what I'll be doing on my 70 once I"m home.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-19-2012, 02:22 PM   #7
Street Smart
Street Smart's Avatar
I always liked the way the BMW headlights looked, are they 5 1/4 ?
I`d like to use something like that in my GMC as long as it can be clean install.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 01-19-2012, 08:18 PM   #8
dougo
dougo's Avatar
anyone one have recommendations on where to purchase the headlight relay upgrades? I'd prefer to buy from a board sponsor... and/or someone that can offer a plug-in and go option (looking for easiest and most cost effective with minimal mods - like the stock look, just want to go brighter).
Thanks,
Doug
Doug
Old 01-20-2012, 12:47 AM   #9
lowrollin70gmc
Too many projects
I wired up my relays myself and there are a few write ups on here, but for originality I don't know of a kit, maybe Wes at Classic Heartbeat, Brothers, or GMCPauls.
The BMW ones are 5 3/4 and here is where I got the idea, but I just wired some up on my tow rig and they have different connectors so it's best to grab some from a junkyard and clip wires. I plugged with blades into the stock connectors for a quick solution.
66 Chevelle w/ BMW Lights
Andrew
Old 01-20-2012, 09:53 AM   #10
Street Smart
Great info, did you have to trim the radiator support at all to make them fit?
Old 01-20-2012, 06:08 PM   #11
dougo
dougo's Avatar
I had a email exchange with Paul Jr. at GMCPauls... thought his comments would be well suited for this thread.
Paul Jr.'s Comments:
First off you should make sure that the headlights are properly positioned its amazing how much more efective the lights are when pointed correctly. One way to increase light output while not having to change anything is to clean all the terminal contacts at the headlights and make sure that the ground wires are clean also, doing this I've seen light output increase tremendously. If you are still running a alternator with a external regulator then you should switch to a internally regulated alternator for improved lighting at lower engine speeds, externally regulated alternators do poorly at low engine speeds causing dim or flickering headlights. You can also replace the current high beam only headlights with high / low beam bulbs and then source a couple of headlight connectors for high / low beam in the Do It Help section of your local auto parts store and then splice them into the low beam side so that all 4 headlights are lit on low beams and when you hit the high beams they still are all lit. This method allows a significate improvement for a low cost and still keeps you legal by not exceeding the original bulb wattage allowed on low beams.
The federal government has begun cracking down on the states not enforcing headlight requirements and its actually against the law to increase the wattage output of the bulbs themselves beyond the original stock wattage. So if you go to a higher wattage bulb you risk being ticketed for excessive light output.
Hope this helps!!
My Best Regards
Paul Jr @ GMCPaul
Doug
