Trailblazer SS pacesetter headers fit 67-72???
Hey guys i was curious if anyone has tried these headers in their 67-72 LS swap...
they "look" like they would fit... http://www.ebay.com/itm/PaceSetter-Q...item2317e50aa2 i just worry about how low they will hang....
Re: Trailblazer SS pacesetter headers fit 67-72???
If people want to try them, I usually have the best prices on pacesetters :-)
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
meowMEOWmeowMEOW
I can offer this bit of insight.
When I went to buy my trailblazer ss cast manifolds, the owner had a new set of long tubes for his tbss waiting to go in. He let me fudge around a bit and we looked, at the clearances to see if his new headers would work. The area where the headers overlap and merge is too wide compared to the cast manifold, at least in my application (66 with mount adapters, sitting about 1" forward.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
If you need measurements on the stock 2010 f-body manifolds let me know.
will get them on here tomorrow before i head to work (starting night shift).
for the time being, here's a set on ebay that i accidentally bid on before i realized i already had a pair. http://cgi.ebay.com/ws/eBayISAPI.dll...=p5197.c0.m619
Measured the manifolds, the farthest they stick out from the cylinder heads looks to be 3-3.5". And thats not counting the flange, thats just the straightway where all the tubes come in. Both flanges seem to stick out about 5-5.5" at their farthest from the flat flange on the back of the block that bolts to the tranny. The driver's side flange hangs down 6.5-7" and the passenger side hangs down about 7-7.5" from the center of the last manifold to cylinder head bolt.
I am very interested to see if this will work as I am about to make a header purchase. I was leaning to the camaro dynatech headers 68gmc used but this might be a alternative.
Posted via Mobile Device |
#12 | |
#13 |
I have used the canaries headers in the past and didn't like hoe much reining I had to do to the pass side frameto get them in and the driver kick out.
#14 |
Anyone ever try tbss headers?
#15 |
i tried the pacesetters on my 66 and the headers fit fine, but the crossover pipe wouldnt work. I think they would work just fine, but you would have to fab up the exhaust starting at the header outlet.
Trent 12 Cadillac CTS-V 07 Sierra HD 4x4 Duramax 66 C10 Short Wide 63 Chevy II(nova) |
| Bookmarks |
