04-25-2003, 09:55 AM | #1 |
Transmisson
I have an '85 with a 305 and 350 tubro transmisson. When I put the truck in gear, the trans will not engage. I give the gas peddle a push the truck will not move. I just had this trans rebuilt a year and half ago. Is the trans shot or is there something else that might be the problem? I am not mechanic, so please give the answers in simple terms.
Thanks Joe Last edited by jlaw'85; 04-25-2003 at 09:58 AM. |
04-25-2003, 10:38 AM | #2 |
I would look at the linkage first.
With the truck off....have somebody move the lever and look to see that you linkage is moving at the trans. |
04-25-2003, 11:18 AM | #3 |
Insert Witty Text Here
Also, make sure it has enough trans fluid in it.
Slonaker |
04-25-2003, 11:22 AM | #4 |
Yeah, sounds like there may not be enough fluid in it.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
04-25-2003, 12:40 PM | #5 |
Fluid is very very important to automatic transmissions. They will not operate correctly without the proper fluid at the proper level.
I agree that you check the fluid level and linkage. Before this problem started did you notice any weird sounds?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
04-26-2003, 09:45 AM | #6 |
Robert Olson Transport
it also depends on the type of the rebuild kit the rebuilder used. Anytime ive gone to one of those mom and pop shops and theyve used the cheapest parts they could find ,i kill the tranny in about a year. Lately ive found a rebuilder who uses the factory rebuild kits( at least thats what im told) that are made by the factory for the truck itself, and ive had no problems, and i beat the hell outta my truck hauling waaay too much weight for waaay to long a distance.
If youre guilty of beating the hell outta your truck first off you should install a tranny cooler to make sure that the heat is disappated as heat is what kills the fluid and then the tranny. If your truck aint going into gear first off check the fluid level and the fluid color. If thats good then go under and check the linkage with both the emergency brake on and someone in the truck stamping on the brake pedal. if both of those check out ok, and the electrical wires are properly hooked up its time for a tranny good luck
04-26-2003, 10:23 AM | #7 |
Man...I second what Old Rusty said there,
I have the largest cooler made and plumbed it with 3/8" stainless (rubber hoses leak) and my trans temp guage never gets over 225F. This is when hauling 8000lbs too. If anybody needs....I have a extra stacked-plate cooler NIB that I don't need. |
04-26-2003, 10:36 PM | #8 |
BAD BOW-Silverado XST
Welcome to the site.
Did you find the problem? |
05-05-2003, 09:51 AM | #9 |
I worked on this problem over the weekend. The transmisson is full of fluid and the linkage is working. The problem is that when the truck is put in gear, I have to give it a lot of gas before it will move in either forward or reverse. For example, I have to stomp on the gas pedal to get the truck to go on some ramps. Does this sound like my transmisson is blown or could this be something else?
Thanks Joe |
05-05-2003, 10:06 AM | #10 |
You get what you pay for
Sounds like bad news. Sounds like tranny rebuild/replace time to me. Just make sure to not take it back to the same shop who rebuilt it the last time.
Just curious. Did this problem just all at once happen, or did it sort of start off slowly and work it's way up to not working at all?
Mike 1985 Chevy C-10 |
05-05-2003, 10:58 AM | #11 |
This happen all at once! I was driving on the highway doing about 60 mph when i noticed my truck was acting like it was in netural. I pulled over and shut the truck off, turned it back over and put it in gear and everything was fine. The next day the truck seemed like it did not want to shift out of first gear. What sucks is that I had this rebuilt about two years ago with a B&M shift kit in there. (it has a trans cooler setup) I thought it would last longer than this?
05-05-2003, 12:26 PM | #12 |
It may be something as simple as the converter being shot, if you call that simple. Did you install a new converter when you had it rebuilt?
I'm no tranny expert, just guessing at things I think it might be. Hope it ends up being something that doesn't cost you a arm and two legs. |
05-05-2003, 02:12 PM | #13 |
its bye bye time. if the trans is slipping, or acting like its going into neutral, you've got something broken internally somewhere. when that happens, the fluid flow distributes the debris throughout the trans. time to bite the bullet and replace it again.
05-05-2003, 03:31 PM | #14 |
"The dude abides"
I am very limited on my transmission knowladge so I am just telling you what I would check.
First, did you replace the torque converter when you had the transmission redone? Second, what is your fluid like? Take and wipe your finger in it and rub your fingers together. (make sure your hands are clean) do you feel any grit in it? Does the fluid smell burnt? I would say that it sounds like the torque converter went out. But I am no expert by any means! But the way that it happened all of a sudden, I would suspect the TC. Usually clutches will start to slip before hand. Were you towing anything at the time?
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
05-05-2003, 09:55 PM | #15 |
I'll admit I'm no expert either, I've done a tranny rebuild or three but that's about it. I'd say look at the converter first though. I'll keep my fingers crossed for ya cuz replacing the converter is gonna be quite a bit cheaper than having the tranny rebuilt or replaced.
Matt '82 Chevy SWB |
05-06-2003, 12:45 AM | #16 |
DO NOT PUT A NEW CONVERTER ON A TRANS THAT IS POSSIBLY TOASTED! that's an excellent way to put debris in a known good converter, making it useless unless its cut apart, cleaned and welded back together which isnt cheap.
05-06-2003, 08:29 PM | #17 |
yeah, find a used one to try first, cuz ya never know. The shop I go to has a couple stock one's in their shop for testing, hopefully you can find one somewhere nearby.
