manual trans and clutch set up????
Thinking of swapping from auto to manual trans in my 54/s10 project. Can anybody tell me or show me how difficult it is to set up hydraulic clutch. And can I just use the clutch /brake setup from the s10? Thanks
Posted via Mobile Device |
Re: manual trans and clutch set up????
Biggest thing I've been told is to match the bore in the master cylinder with the bore in the slave (assuming they're out of different vehicles). You should be able to get adapters to AN fittings and then be able to run a braided hose to make it easy.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Thanks bluejeep. Im still debating on using the auto or manual I have
