Old 01-09-2012, 04:48 PM   #1
m455sx
m455sx's Avatar
2003 GMC Crew cab
I was wondering if some one know the best way to wake up a factory 8.1L motor as in simple upgrades. I heard the computer or mas sensor hold engine back because it has to much power.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 01-09-2012, 06:57 PM   #2
bighaas79
Re: 2003 GMC Crew cab
they have torque management programmed into the pcm to retard the timing when you get on it to protect and extend the life of the transmission. Otherwise they make so much torque it will eventually toast the tranny. You can have it programmed out but be prepared to improve the trans, or be replacing it.
bighaas79 is offline   Reply With Quote
Old 01-09-2012, 11:38 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Nice truck!
www.blackbearperformance.com for a custom ecm tune - do your bolt on mods first, then get the tune.
headers, 2.5" duals is a good start, maybe a K&N FIPK. That's pretty much what I do to all my vehicles to wake them up.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-10-2012, 09:15 AM   #4
m455sx
m455sx's Avatar
Speaking of duals i had to go with a dual in and out magnaflow muffler as i kept breaking mufflers. They would over heat and crack. 1st one was a turbo muffler dual in and factory single out , 2nd was flowmaster dual in and factory single out and now on 3rd one dual in and dual out with 3" pipes go just over rear axle. They only last 9 months. The magnaflow now is definatley discolored a reddish purpleish color. I tow a 35 ft campring trailer with a golf cart in the bed, with all other cargo about 10k lbs. The truck checks out OK on the computer but i think it is running lean, but only gets 8 mpg? Any advise will be appriciated.
1970 Cutlass SX
1962 Chevy Stepside
Old 01-17-2012, 08:23 PM   #5
m455sx
m455sx's Avatar
bumb
1970 Cutlass SX
1962 Chevy Stepside
Old 01-17-2012, 09:29 PM   #6
clinebarger
bumb
The stock exhaust system was made to handle a big gas engine while towing with converters, Aftermarket is NOT. If you remove the converters & have a custom tune done, Your mufflers will last longer.
clinebarger is offline   Reply With Quote
Old 01-18-2012, 09:42 PM   #7
m455sx
m455sx's Avatar
thank you for the info.... will after market converters work?
1970 Cutlass SX
1962 Chevy Stepside
Old 01-21-2012, 10:29 PM   #8
clinebarger
I recommend you install the factory exhaust back on the truck.
You can remove the cats all together & have the catalyst monitors turned OFF with a custom PCM tune, No check engine light, Will pass emissions as long as they dont do a visual on the converters. Its against "federal" law to do this.
Old 01-21-2012, 10:56 PM   #9
m455sx
m455sx's Avatar
factory stuff is long gone.... plus i like to hear the rumble of the exhaust.
1970 Cutlass SX
1962 Chevy Stepside
