04-25-2003, 10:31 AM | #1 |
Lowering Questions:
Alright, I did a search and had way to many returns for an easy answer.
I want to put a 3.5-4/6 drop on my 70 chevy SWB, I have coil in the rear. I am going to be using drop spindles with lowering springs in the front. Here are my questions for the rear: 1) What should I use to keep a softer ride, yet not bottom out? 2) Why would I use airbags? I know I can adjust the height with them, but is that the only reason to use them? TIA |
04-26-2003, 10:25 AM | #2 |
i put a little info on the FAQ section, it might be of some use to you. good luck!
04-28-2003, 09:30 AM | #3 |
Thanks, I didn't look there yet.
