01-09-2012, 06:50 PM | #1 |
big pblock, big truck, some cam ?'s
Hey all,
I am rebuilding/replacing the engine in my C60. It is tall deck truck block, the 427 kind. I ended up with a brand new short block, sans cam. I have the original small port small valve truck heads, recconditioned and ready to go on, no port work, no trick springs....stock (for the truck) valve size. Obviously this is a big heavy truck, but it won't be asked to do really heavy truck stuff. More like a recreational tow rig, or a one ton pickup, (as compared to say a dump truck) anyway, it will keep its stock manifold and big Q jet, and its big cast iron exhausts, but will get true dual exhaust. With a big double disk clutch and its small valves I am not building a race motor. But I would like decent runner that's sounds healthy and gives me my best shot of being a good match for the combo. I don't know how the stock cam performed or how it was specced or if I can even still get one. I also don't know how much lift this head/spring combo will accept. Would a small after market hydraulic roller be suitable? Got any recommendations or words of advice? Thanks, Dan Posted via Mobile Device |
01-09-2012, 07:03 PM | #2 |
Re: big pblock, big truck, some cam ?'s
I would call the cam manufacturer and tell them what you have and what you want it to do so they can recommend a cam for you.I did that last year when I built my 396 .called comp cams and used the cam they recommended and am very happy with it .
01-09-2012, 07:07 PM | #3 |
I talked to comp cams and maybe it was just the person I talked to, but I was less than impressed. I told them I had a C60 with a 5 speed and a 6.91 rear end and they asked what kind of R's I was turning in the 1/4.
01-09-2012, 07:30 PM | #4 |
I think I would talk to someone else then ....just sayin. Don't remember who I talked to but we didn't talk about 1/4 mile !!!!
Posted via Mobile Device Last edited by mixermike; 01-09-2012 at 07:47 PM. |
01-09-2012, 09:23 PM | #5 |
The times I called the cam help techline it always proved to be good advice. I would say the a cam like the High energy 268h is always a good choice for light builds Or you might think about a split design cam since the valves are smaller than a normal bigblock. Like a dual energy 260ish. I think it would be hard to beatsomething in that range.
01-09-2012, 09:36 PM | #6 |
No one has any real experience with the truck heads? What kind of lift will they take? Is there any benefit to going with a roller ? In short ....Has anyone actually built a truck block in a truck?
Oh and thank you for the advice so far...keep it coming oh and where would I get a stock cam if I wanted to do that? Posted via Mobile Device |
01-10-2012, 04:37 AM | #7 |
Call Clay Smith Cams in Southern California.
Ask for George Streagal, he should be able to help you out pretty good. Only cams I'll run in my stuff, I have probably 4 on the shelf, along with a bunch of random ones my grandpa collected when he was still around doin BB stuff. |
