04-25-2003, 10:55 AM | #1 |
Wobbly bed sides - How to fix ????
I'm not sure I spelled wobbly right but the problem is that my bed sides lean inwards at the top.
What's wrong? How do I fix it? I've been told that this is a result of running a truck without a tailgate. I guess this causes a lot of flexing. Where the bedsides join the floor in the rear, there is a crack in the seam. It looks like someone had glued the seam. Any ideas?
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
04-25-2003, 11:18 AM | #2 |
it is actually supposed to be welded on the bottom where the bedsides join the floor. this keeps it from flapping in the breeze
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
04-25-2003, 11:27 AM | #3 |
Maybe I'll grind out all of the caulk/crap in those corners. Then reweld it?
04-25-2003, 02:07 PM | #4 |
Yep, there is supposed to be a factory weld right in the rear corner, but sometimes they do look like caulk
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
04-25-2003, 03:52 PM | #5 |
Thanks for the info.
04-25-2003, 04:10 PM | #6 |
It could be more than just the welds (one horizontal and one vertical). If you feel around under the real corners there should be three bolts holding the post to the rear crossmember. They could be loose or missing. Here is a pic of the crossmember end showing how the bedside is attached.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 04-25-2003 at 04:13 PM. |
04-25-2003, 04:24 PM | #7 |
If I were you I would not re weld it, becasue it is a major pita if you ever want to take it apart again. Check the bolts, and that should help a lot
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
04-25-2003, 05:35 PM | #8 |
Naaa, weld the hell out of it! It will stiffen it up and keep it from squeeking and rattling.
04-25-2003, 06:28 PM | #9 |
i forgot about the bolts, but i agree with randy. besides, that is the way it is supposed to be. do you plan on taking it apart anytime soon?
04-26-2003, 09:04 AM | #10 |
Oh well, when I put mine back together I didn't bother welding it. Still solid as a rock after 3 yrs. But there could be a chance that your bolts holes are all rotted out so the only alternative is welding.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
04-28-2003, 09:15 AM | #11 |
I'll have to get under there and take a look. I'll check the bolts first. I have a feeling that the area is rotted out. I hate to weld it up and not be able to take it apart but I bet that's the only way I'm going to be able to fix it.
Thanks for the info and the customized picture!
