![]() Join Date: Jan 2005
Gas tank sealer question
I am trying to install the liquid sealer in my gas tank. I have flushed it, degreased it and flushed it again. My problem is no mater what I do and how long I let it sit I can't get all the water out of it. The instructions say if there is water in in the sealer will no stick and will flake off in sheets. Heck I have even tried a heat gun, but there still seams to be moisture in it. Do I really need to get this bone dry or can it have a little moisture??
Re: Gas tank sealer question
I used the POR system on my Vette's tank in 2009. For drying, this is the setup I used. Small electric space heater, a fan, and a funnel. Blowing warm air thru the tank for at least 24 hrs will dry it out. I used what I had on hand. Just an idea for you to consider.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
dump a quart of acetone in the tank slosh around dump and dispose and dry out with a fan blowing in the filler tube and out of the sender hole should be dry in 1 hour
Fuzzy |
