sbc pulleys and p/s brackets
I need sbc p/s brackets, water pump pulley (1 or 2 groove), and crank pulley (2 groove). I am useing the 67 style alternator bracket so anyone with pulleys and p/s brackets that will work please post!!!!
Member #1049
Re: sbc pulleys and p/s brackets
Need a bit more info, What power steering pulley do you have? There were several different version from 67-72..
Or I have a correct 67-68 set consisting of water pump pulley, both crank pulleys, power steering pump pulley and brackets for $75 shipped to your North Dakota zip code |
C10 addict
I have a factory sbc pulley and bracket setup off of a 1972 C10 with a/c and power steering. The brackets include the alternator and P/S, the crank pulley has the removable extra groove for the A/C. I can include the power steering pump with hoses as well if you need it. Let me know if you are interested and Livrat doesn't have what you need.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
Hey thanks guys ill explain my situation basically I choose the 67 style alternator brackets because I am running camel hump heads and they got no accessory holes in the front of the heads! I was hoping I could use the same p/s pump as what I had when the motor was a stock 350 with the long water pump style set up by just changing the brackets and pulleys! Or do I need a specific pump for swp set up?
Posted via Mobile Device |
Member #1049
I order to use the 67 style alternator brakets you will have to use all short water pump stuff, including pump
mahanian: I dont think your set up will work because you need the front accessory holes in the heads. But thanks for replying!!!
livrat: pm sent! |
