Old 01-09-2012, 10:20 PM   #1
franky69c10
chevy runs deep
franky69c10's Avatar
bump stop on lca
putting drop spindles and drop spring do i gotta remove the bumpstop or can i leave it lmk asap cuz i got the grinder in my hand right as i type
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 01-09-2012, 10:28 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: bump stop on lca
I left mine on and trimmed some off the top to gain ample clearance....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-09-2012, 10:30 PM   #3
konakustoms
konakustoms's Avatar
leave them on......Im dealing with that now!!
konakustoms is offline   Reply With Quote
Old 01-09-2012, 10:37 PM   #4
franky69c10
chevy runs deep
So u left them on
RAIDER NATION
My LWB is a SWB now
Old 01-09-2012, 11:08 PM   #5
slugish
Slugish
Leave them on > maybe trim a little ,unless you want to bottom out
slugish is offline   Reply With Quote
Old 01-09-2012, 11:20 PM   #6
konakustoms
Originally Posted by franky69c10 View Post
So u left them on
Leave them on & trim for your liking......Mine were cut off before I got my truck now I have to go to plan B to fix it.......Been doing research tonite on it actually
Old 01-09-2012, 11:29 PM   #7
BMERDOC
BMERDOC's Avatar
I cut the tips off mine so that they were square chunks of rubber to have something soft to bottom out on.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-09-2012, 11:33 PM   #8
konakustoms
Im gonna buy new lowers and start over fixing someone's handy work before I got my truck.
Old 01-09-2012, 11:50 PM   #9
DREAMER1
DREAMER1's Avatar
I cut mine all the way off to give myself more path of travel. If you leave the bump stops in you're going to definetly bottom out. If you remove the bump stops and leave the mount you're going to bottom out from time to time with metal to metal. If you remove bump stops and mount its less likely that you'll bottom out...unless you're playing the dukes of hazard over pot holes all the time. In that case you have more to be worried about that bottoming out your A-arms.
DREAMER1 is offline   Reply With Quote
Old 01-10-2012, 12:51 AM   #10
grs
The bump stops are replaceable. Did someone cut off your steering stops. They did mine.
grs is offline   Reply With Quote
Old 01-10-2012, 01:12 AM   #11
rwhit57
rwhit57's Avatar
I cut mine off completely down to the a-arm. I see no reason to leave them on there unless you just like having your teeth rattled once in awhile.
rwhit57 is offline   Reply With Quote
Old 01-10-2012, 01:15 AM   #12
konakustoms
maybe I just need a set of stops to bolt on like the flip kit then because mine are shaved all off!!
thats what i love about this site.......someone has always tried it 98% of the time.
Old 01-10-2012, 01:24 AM   #13
gGMC DOG
You can run w/o the bump stops but they don't have to be removed. Many people remove them so the bumpstop doesn't limit suspension travel @ the x-member.
My experiences say that if you remove the bump stop, you're only shifting where the point of contact is....
If you still have inner fender wells & the tires are tall enough, you'll have occassional interference there.
If you remove the inner fender wells & bump stops, the lower control arm bushings will make occassional contact (interference) w/the road.
gGMC DOG is offline   Reply With Quote
Old 01-10-2012, 01:39 AM   #14
gGMC DOG
Like most questions on this you can get three people giving you five opinions. If it was mine, I would replace them. Even if you drive on smooth roads you can hit a pothole or railroad crossing or something like that.
I would prefer to slam rubber to steel than steel to steel.
The main purpose of a bump stop is to serve as some final suspension cushion to keep the metal parts from coming together or from traveling too far, which might in some way damage the suspension or chassis
Old 01-10-2012, 02:08 AM   #15
Malo83
Cruzzzn' Vet
Malo83's Avatar
Cut my bumpstops completely off, no problems bottoming out
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 01-10-2012, 11:04 AM   #16
konakustoms
I dont have problems bottoming out & mine are cut off also....I am 6" drop with spindles & springs. MY problem and reason I am installing a stop again is to try to keep the tire from hitting the inner fender well on big dips. Bottoming is not the issue, only thing that hits is tire to inner fender, I have never hit metal to metal even when hauling or towing!
Old 01-10-2012, 11:07 AM   #17
konakustoms
What kinda spindles did you use? Did the wheel rub the spindle @ the caliper?
How did it turn out last nite?
Old 01-10-2012, 12:43 PM   #18
grs
Nice truck Milo. Here is a pic of mine.
Old 01-10-2012, 04:07 PM   #19
Malo83
Cruzzzn' Vet
Malo83's Avatar
Nice grs, and Thanks.
Old 01-10-2012, 06:57 PM   #20
konakustoms
Here is a pic of my lowers the guy hacked before I lowered it the rite way. And a shot of the top.....I know its oily it is just mocked up to drive & now is all coming off to get painted.
Not shure what they cut off but I can see something was cut off the lower.
Like I said the only thing that hits is my tire into the upper part of the inner fender well!
Old 01-10-2012, 08:40 PM   #21
grs
He cut off the steering stop. The bump stop sits on top of the steering stop. Looks like he cut off part of the lower control arm too so the wheel would not hit it. That might be why the tire hits the upper fender well. That is if it hits when you make a sharp turn.
Old 01-10-2012, 10:03 PM   #22
konakustoms
Im buying lowers and redoing it....It never hits turning just on big dips the tires hit the inner fender well tops.
Old 01-13-2012, 04:00 PM   #23
grs
Here is a pic of my new steering stop. I wont know how well it works until the streets are clean of salt, and snow.
Old 01-13-2012, 11:10 PM   #24
DREAMER1
DREAMER1's Avatar
Is that a custom made steering stop, or did you buy it ?
Old 01-14-2012, 11:45 AM   #25
grs
I had to grind part of the old stop off of the control arm. Someone else cut them off. I made a template of the bottom of the stop out of 1/8th inch thick paper 2 inches wide, and 5 and 1/2 inches long. I figured out where to place it on the control arm. Then figured out where to drill a small hole. Flipped it over and placed it on the other control arm, and drilled 3/8th inch holes in the control the arms. The truck has to be on the ground, and turned enough so the wheel almost hits the control arm. Then I drew up the plans and took it to a machine shop, and had them cut, and drill them. They cost $75.00. I will see how well they work this spring. The stop is 2 inches by 2 inches, by 5 and 1/2 inches long.
