283 sbc in a square body?
I paid a visit to a good family friend the other day and he happened to have a 1965 chevy 283 that was free if i got it out of his shed. It is all here and is backed by a powerglide. Just wondering if any of you guys every built a hopped up vintage 283 for your truck. please include pics i you can
Re: 283 sbc in a square body?
If you know what your doing they can be high rpm screamers but low on torque so they are best in lightweight vehicles. The factory 350hp 327 hp cam and some worked 202 heads and a 4 barrel and headers should make a fun drivin truck for DD
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I don't see the point in throwing money at a 283 just for the sake of it being free. Your money would be much better spent starting with a 350 or 400 that wasn't free.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
#4 | |
driving is in my blood
What would pics do? They would look the same as any other small block of any displacement made.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
I have a soft spot for the 283 since that was the first engine I ever owned. It was in a 62 impala ss that had seen better days but man was it cool. That thing was a sled. I have since grown to appreciate "stupid" horsepower but it has also taken me 30 yrs to be able to afford it.
Bottom line is build what you want, not what everbody else wants. xrcr |
Smaller isn't always better if it struggles to pull the load. It's nice to have the torque of a bigger engine if you hitch onto something or need the extra ooomph to pass or get out of somebody's way, and if it's tuned right, mileage will be as good or better.
#7 | |
The 283 is arguably one of the best small blocks ever built. If I have to explain you'd never understand. I'd pay for one over a free 305 any day. I think it would be extremely sensible by what today's needs are to go with a 283. People used to argue about it being worth modifying a straight 6 over a V8 but you sure see a lot of it going on now. A 283 won't struggle to move a pickup and will get better mileage than a 350.
The 283 is a great motor, the only draw back is the canister style filter but there is an adapter for that. They are not that low on torque at around 300 ft lbs(9.5 to 1). If the motor is good and you don't have to throw a lot of money at it to get it running and that's what you want to do, you won't be disappointed. The whole key is what compression ratio it is. If it's a 9.5 to 1 motor it will be good, if it's the 8.25 or 8.5 motor it will be a little weak compared to most 350s.
I'd rather have a 283 or 307 over a 305 any day. If it has a forged crank, then you can really have some fun with it. I wouldn't spend too much money on one though. Take your time and hunt down good deals as you build it.
The key to making a 283 work well is proper rear end gears, and if you are running an automatic a high stall converter is a must. If you run highway gears and tight converter you will be disappointed.
1977 GMC Sierra Grande |
I have a soft spot for the 283 too, since it was in my first truck, a '67 stepside. My dad had rebuilt the 283, drove it for 2 yrs. and gave the truck to me. Then I drove it for the next 17 years. Never pulled a trailer with it(well once, a deck boat), but it did a lot of work over the years. For me, it was the perfect blend of power and economy. It was a sad day when I let her go. If you're still out there ole girl, please forgive me.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
![]() Join Date: Apr 2009
a couple in factory type garb.
one of my favorite engines as far as appearance. |
#13 | |
![]() Face it, 283's are useless. It sounds like it's more of a nostalgia/sentimental reason to use one than anything else. The only reason 305's suck is because they were developed in an era filled with smog regulations and emissions heads/components....and I think maybe the bore is severly limited to oversizing because of the water jackets.
#14 | |
Posted via Mobile Device |
#15 | |
#16 |
Actually, what you are talking about is not true. Every engine will have a different rear end gear and torque converter that it works well with.
I can put 3.08 gears behind a healthy 454 and it will actually run pretty well. The 454 has enough torque to move those gears just fine. However, a 283 would not have such an easy time pushing those gears. Keep in mind, the 305 never made more horsepower than the highest performing 283. The 283/307 have a larger bore which is far better than the smaller bore of the 305. The small bore of the 305 shrouds the valves, and limits how large of valves you can run.
#17 | |
If you want a nostalgia engine, then have at the 283. Not trying to dissuade you. If you want bang for your buck performance, I think you're wasting your time. But if it's free, why not right? Don't be suprised if you feel like you're wasting money on mods though once you start "experimenting" with it. And from a SBC perspective, I don't think there is that much aesthetically different from a 283 vs a 350. But, wouldn't the looser converter and lower gears defeat the purpose someone else posted about the benefit of the 283....as in mpg's?
#18 | |
The key to making a 283 work well is proper rear end gears, and if you are running an automatic a high stall converter is a must. If you run highway gears and tight converter you will be disappointed. Your quote: Is this not true of any N/A engine? True or False? False. A 283 with highway gears and a tight converter will be disappointing. A 454 with highway gears and a tight converter will work fine. What is true for the 283 is not true for the 454, thus making my original statement false if you apply that thinking to all N/A engines. Not every engine needs a numerically high gear and a loose converter to work well. Yes, most N/A motors will work better up by enhancing gearing and the torque converter within reason, but it is not a required for all N/A motors to provide good performance.
#19 | |
I know this ain't a truck,but just for fun: http://www.google.com/url?sa=t&rct=j...vfy9fg&cad=rja I recall a time 4wheelin' with my buddy in his '79 F250 with a 400,another guy with a '79 Dodge W200 with a 400 or 360,and this other guy's '77 K/30 with a 283 that spanked those trucks every which way. I mostly recall a hill climb. That 283 ate it up way better than that 400 or 360. That truck had no shortage of mite. He would have topped the hill if it hadn't been for torquing the clutch z-bar out of place at a certain spot on the hill. This was a big black K/30 with at least 36" tires. I'm pretty sure that 283 had torque.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-10-2012 at 09:51 PM. |
#20 | |
Anyway, I'm always up for talking engines...when they are engines worth talking about. And a 283 has never violated me in any way...I could counter and ask what a 283 has ever done that's so spectacular that a 454, 427, 396, 350 etc couldn't do? Either way, just offering some advice to the OP. He doesn't have to take it. I would be interested in how he likes the mods on his 283 once he sinks a couple $100 into it. ![]()
#21 | |
I like the stereotypical story of a buddy and 2 other guys have 3 different brands of trucks, the 2 x-brands having their best engine and the brand you prefer having an economy engine but the brand you prefer magically outperformed the other 2.....I've heard stories like these countless times and they never make any sense. Reminds me of the stories of guys claiming they can pull the front wheels of their street car high enough to clear a long neck beer bottle...I do get to use this icon though that I've been dying to find a use for.... ![]() ![]()
#22 |
#23 |
I kinda like a 565 myself...that's two 283's
![]() The 283 was the hot lick for a lot of years, but bigger bores and longer strokes took over once they were engineered. 283's are actually getting very hard to find and command a pretty penny if you have the right one. The 283 engine was a major player in the demise of the old flat head engines. For a small power plant, they packed quite a punch in their day. When you get right down to it, all Chevy small blocks (and big blocks for that matter) are derivatives of the little overhead valve mouse motor. They've been kicked aside by folks looking for more power, their small bore limits breathing ability which is THE major contributor to making power. I'd kinda like to build one with more modern heads, induction and cam, you could probably get great mileage in a light to medium weight vehicle. |
#24 |
Old Heap Driver
My 65 Chevelle (daily driver) has a 283 and powerglide automatic. The motor has nearly 150k miles on it and still runs strong. The car has plenty of pep and will hang with the best of them on the interstate. I have zero complaints concerning my 283!
But, I don't see myself spending any money on it should there be any sort of major failure. I'd grab me a nice 350 (because they're plentiful) or look at one of the 5.3 LS based motors.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#25 |
You guys are missing the point I ran 7 sec 1/4miles with a king cab duelly and a 283 with a one billion shot of nos and 8 turbos and a two barrel.
Duntov 350hp 327 cam fuellie heads a four barrel and some headers with whatever converter/gears will be fine with that you can go both ways 2800 stall with 4.11 gears for some fun or 3.23 gears and a 700r4 for some fun stop light and daily driver action. Either way why not run a 283 with those mods? All of it can be transferred to another engine just a easy. Posted via Mobile Device
