Old 01-10-2012, 02:34 AM   #1
BAMO
Fuel Line Fitting
I need a little help with the inverted flare fuel line fitting. The little gasket that went on that fitting is toast (between carb and fitting). I also need a new inlet fitting. Truck is a 65 c20, 283, with I presume the stock rochester carb on it.
So the questions are:
  1. If I get the inverted flare fitting, or more importantly, what are the dims I need - similarly what are the dims that I need to be aware of for the hardline that runs out of the inverted flare.
  2. Where can I get that gasket (I think it is a 7/8 but am not sure) and what exactly am I looking/asking for - aside from it being supplied with the inverted flare.
  3. Lastly what other options are there besides the stock inverted flare with hardline - any suggestions?
Thanks in advance for any help. I know the questions are pretty rudimentary but any help is appreciated (and I really don't want to take it off yet again to measure, and order 3 of the wrong things before I get it right).
BAMO is offline   Reply With Quote
Old 01-10-2012, 09:12 AM   #2
1963c-10
1963c-10's Avatar
Re: Fuel Line Fitting
I used a 5/16 inverted flare fitting on mine made for an auto trans w/barb on the other end....got it from summit for like 4.99. I had trouble finding the larger gasket that goes directly into the carb myself, found an old one on another carb I had. Then I got rid of the hard line and ran rubber in place. ( I wanted a fuel pressure guage and filter inline).
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-10-2012, 10:13 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
You might find your needs here....
http://www.thecarburetorshop.com/Carburetor_ID.htm
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-11-2012, 12:48 AM   #4
BAMO
Thanks. Think I found everything I needed here - http://quadrajetparts.com/rochester-...s-c-72_87.html
