Old 01-10-2012, 10:02 PM   #1
big mike71
big mike71's Avatar
Lowering?
If I go with a 2 1/2 x 4 drop for now, but later decide I want a 4 1/2 x 6 would I have change everything again or would I be able to use the same shock relocators and panhard bar.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 01-10-2012, 10:03 PM   #2
jondancer
Re: Lowering?
You will always want to go lower. Start with the 4/6 !
jondancer is offline   Reply With Quote
Old 01-10-2012, 10:23 PM   #3
big mike71
big mike71's Avatar
Re: Lowering?
If I do I'll have change out my headers and I don't want to do that yet.
Old 01-11-2012, 12:17 AM   #4
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: Lowering?
You should be able to reuse the shock relocators and panhard bar- assuming you're putting in an ECE type adjustable unit. If your running a stock arm, you'll need to upgrade this part.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 01-11-2012, 08:15 AM   #5
Re: Lowering?
ECE draws the line between 5" & 6" for adjustable panhard and Super panhard. I only know of one shock relocator kit.
Old 01-11-2012, 12:47 PM   #6
big mike71
big mike71's Avatar
Re: Lowering?
Thanks guys, I know I'll want to go lower later, but for now 2 1/2 x 4.
Old 01-11-2012, 06:18 PM   #7
jondancer
Re: Lowering?
What do you mean by ,they draw the line? I have the super panhard and the 6" drop in the rear but plan to put a 2" blocks in for a total drop of 8" in the rear.
Old 01-11-2012, 10:29 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Lowering?
do the 4" drop and add blocks later on in the future for a cheap 2"
John
1999 Toyota Tacoma 4x4
Old 01-12-2012, 02:42 PM   #9
big_al_71
big_al_71's Avatar
Re: Lowering?
I have the ECE panhard bar and zero issues aired out also the shock relocators so you will be fine mike.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
