Old 01-11-2012, 03:02 AM   #1
pulltilbroke
pulltilbroke's Avatar
No Rear Light(60 K10)
Ok so a while back I lost all rear lights, Blinkers tails and brakes. So today I started looking around and found this switch on the top side of the column close to the fire wall was all busted. Where can I get one of these or is it a junkyard Item? Also was is the correct terminolgy for that switch.
And yes I know the master cylinder leaks
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 01-11-2012, 09:03 AM   #2
j.kirn
Re: No Rear Light(60 K10)
That is your turn signal switch and classic parts of america has it or e-bay. On the left inside of your cab on the floor by the seat there is a electrical plug for the wiring harness to the rear check that has a cover to it.
j.kirn is offline   Reply With Quote
Old 01-11-2012, 11:13 AM   #3
pulltilbroke
Thank you!!
I'll check here in a bit.
Found it!!
http://www.classicparts.com/1960-62-...ctinfo/53-506/
Old 01-12-2012, 12:57 PM   #4
Rooster's 67
Rooster's 67's Avatar
Might want to check that master cylinder, looks like it is leakin inside the cab.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-12-2012, 01:24 PM   #5
j.kirn
I think he already stated that he knows its leaking
Old 01-12-2012, 07:15 PM   #6
pulltilbroke
Yeppers it leaks pretty good, I got a new one that I have yet to throw on there.
