Old 01-11-2012, 08:17 AM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
moving hanger and shackles
Will moving the hanger and shackle up one hole on the frame work on my one ton? I know it works on 1/2 tons thanks
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 01-12-2012, 08:19 PM   #2
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: moving hanger and shackles
lol anyone?
Old 01-12-2012, 09:15 PM   #3
ghettoluxury
ghettoluxury's Avatar
Yes you will gain about 3 inches.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-12-2012, 09:20 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
thanks because with the springs i have in my truck it sits 3inch higher than it should after i put drop hanger and shackles.
Old 01-12-2012, 09:34 PM   #5
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
do you move both up? because i just looked at my pics and my shakle holder has only 4 rivits....
Old 01-12-2012, 09:36 PM   #6
ghettoluxury
yes you have to grind the heads of the rivits off and punch them through the frame then replace with Grade 8 bolts.
Old 01-12-2012, 09:39 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
no i know that as i did that with my hanger but if i move the shackle hanger up only 2 holes with be lined up with the frame will only 2 be enough? lol noticed i missed some info in my last post fixed it now.
Old 01-13-2012, 12:38 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
No, two is not enough. You will need to drill two new holes.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-13-2012, 12:42 PM   #9
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
thanks but i just was looking under the truck and i have to do a stock spring pack swap as my 2inch shackles already almost hit the bed floor
Old 01-13-2012, 01:23 PM   #10
ont_guy_38
ont_guy_38's Avatar
Ya in the rear you have to do shackles or move them , one or the other not both
ont_guy_38 is offline   Reply With Quote
Old 01-13-2012, 01:26 PM   #11
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
the prob is the ark are my springs because it use to be a tow truck and had 26 leafs aside :S
Old 01-13-2012, 01:42 PM   #12
Racker
Racker's Avatar
Had the same springs in mine when I did my BUDGET drop. Ended up taking out 16 leafs, i would have to go look in the snow bank. Replaced the centering pin, used STOCK shackles and moved BOTH hangers up the frame. Not as low as I want it but it works for now.
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!"
Racker is offline   Reply With Quote
Old 01-13-2012, 01:43 PM   #13
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Originally Posted by Racker View Post
Had the springs in mine when I did my BUDGET drop. Ended up taking out 10-12 leafs, i would have to go look in the snow bank. Replaced the centering pin, used STOCK shackles and moved BOTH hangers up the frame. Not as low as I want it but it works for now.
yeah i took 20 leafs aside out and used 2inch shakles and 2inch hangers but i still have 3 inch wheel gap
Old 01-13-2012, 02:03 PM   #14
Racker
Racker's Avatar
Holly Cow, I'm guessing mine where a little softer than yours. Have you moved the hangers up yet?
Old 01-13-2012, 02:04 PM   #15
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
no cant the shackle is already almost touching the bed.
Old 01-13-2012, 02:26 PM   #16
Racker
Racker's Avatar
Just read your WHOLE rig build up. And then went and looked at mine. YEP, my springs settled out more like the other guys. If you got a good yard around the area, I would go and look for a set of 3/4 ton springs. Might cost up a little money but a lot less work. Just my opion to help out a fellow dually.
Old 01-13-2012, 02:35 PM   #17
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
3/4 will work?
Old 01-13-2012, 08:07 PM   #18
Racker
Racker's Avatar
I beleive the will, dont see why they wouldn't. Or see about getting some one ton leafs that dont have as much arch as yours does. Just trying to help but depending on how low you want to go, I say BAG IT. That is where I'm headed with mine. Good luck and GREAT work so for.
