01-11-2012, 11:19 AM | #1 |
Ls2?
I've been posting this in a few places here trying to get as many replies as possible so I can make an informed decision.
I'm building a pro-street themed 57 P.U. and have come to the time to make a choice of the power plant. #1-Build my new bare block 454. Needs everything. #2-Get a complete 1999 454 vortec from a salvage yard that has 90,000 miles. Will have to go through and freshen/replace what is worn out. It does have all the accessories and comes with the computer for the FI. The engine is $1,000. Would still need a trans. #3-6.0 LS2 out of an 2009 SS Trail Blazer. This engine is only supposed to have 18,000 miles and has the trans and computer also. $5,000 for both. thanks for any reply's. Kim |
01-11-2012, 12:52 PM | #2 |
meowMEOWmeowMEOW
Re: Ls2?
#4 build an lq4/lq9 and trans with good aftermarket goodies for under the cost of the LS2.
The ls2 is awesome, especially with those low miles, but its not the vision I get when I think "pro street". I also imagine that the cost will mean that the motor will stay mostly stock at that point. IMO for what you'd spend, you can build an lq4/lq9 more tailored to your goals, and still have some money left for other stuff. Also, wasn't the TBSS awd? I'm not as familiar with the 4l65e so I don't know if you'd have to switch the output shaft on it as well. Cool project no matter what ya do. (come to the darkside!)
01-11-2012, 07:42 PM | #3 |
Re: Ls2?
I agree with the points about a LQ4/9 being more budget friendly. But if you can afford it.....LS2 all the way, They are factory high performance engines & produce great power with just a tune.
The transmission will be a 4L70E that will have a transfer case on it, Need to swap the output shaft, Install a 2wd tailhousing. |
01-11-2012, 08:27 PM | #4 |
Re: Ls2?
I agree as well with the lq4/lq9, super strong iron block if your gonna run nitrous or turbo...but if money's no prob the ls2 would be pretty sweet.....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-11-2012, 09:32 PM | #5 |
Re: Ls2?
Build an lq9 with l92 heads and an appropriate spec'd cam. You can run carb setup or fuel injection either one. This will make more power reliable power for less money than any of the 3 options you are looking at. Good luck with the build.
Posted via Mobile Device |
01-11-2012, 11:44 PM | #6 |
Re: Ls2?
Thanks guys.
I'm going to show my ignorance now. What vehicles came with the Lq4/Lq9? Kim |
01-12-2012, 04:49 AM | #7 | |
Re: Ls2?
Here's a pic of the set up. Kim |
01-12-2012, 09:12 AM | #8 |
Re: Ls2?
The lq4 comes in most 3/4 ton pickup trucks and some earlier Denali pickups and suv's. The lq9 comes in escalades, Denali trucks 04-up for sure, some regular pickups. The only difference between the two is the piston shape. The lq4 has a dished piston and the lq9 has a flat top piston. Everything else is the same. The ls2 pictured is a great engine but most of us can't afford to pay that much for an engine setup. The lq4 and lq9 are 6.0l just like the ls2 but the iron block adds weight. The ls2 heads are probably 243's which will bump compression up some. Good luck with the build.
01-12-2012, 11:07 AM | #9 | |
Re: Ls2?
I really can't afford it either but when I start adding up what it would cost to build my bare block or go through one from a wrecking yard and then getting a good O.D. trans it doesn't look that bad. Kim |
01-12-2012, 11:25 AM | #10 |
Re: Ls2?
I know the 6.0 is the bigger and possibly a better choice to do it once but my little 5.3 sure is fun and to me makes good power. You can pick them up with a over drive much less than that. Dont forget you will spend on tune, wiring and all the other necessary parts will quickly add up.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-12-2012, 12:08 PM | #11 | |
Re: Ls2?
Kim |
01-13-2012, 09:34 PM | #12 |
Re: Ls2?
Well here's what I ended up with.
6.0 LS2 with a 4L70 trans. Only has 18,000 miles. Has all the accessories, computer and harness. Now the fun can begin. I appreciate all the advice you guys gave. Kim |
01-16-2012, 12:25 PM | #13 |
Re: Ls2?
awesome project good luck.
Dave
02-12-2012, 08:20 PM | #14 |
Re: Ls2?
if ya dont mind me asking whatd was the price for the Ls2 with the transmission?
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842 |
02-12-2012, 09:23 PM | #15 |
Re: Ls2?
sweet!
02-12-2012, 09:40 PM | #16 | |
Re: Ls2?
I kept hearing about guys getting cheaper ones but couldn't find any in my area without a lot of miles. I pulled the pan and everything looks good and the trans fluid was clean so I should be O.K. Kim |
02-12-2012, 10:58 PM | #17 |
Re: Ls2?
Seems like a decent deal. Is the trans 2wd or awd?
02-12-2012, 11:01 PM | #18 |
Has more rust than truck...
Re: Ls2?
I agree,you can easily get a 6.0 for less, but not a LS2.
02-13-2012, 01:07 AM | #19 | |
Re: Ls2?
Kim |
02-13-2012, 01:09 AM | #20 | |
Re: Ls2?
Kim |
