Old 01-11-2012, 01:37 PM   #1
remist17
remist17's Avatar
How to remove window washer fluid from 2005 Silverado
I put some washer fluid in my truck last night and half way through putting it in I got a smell of rotten eggs (sulfur). How do I get about 1 gallon of washer fluid out of the tank? I was thinking of sticking my wet/dry vac in the hole but I dont think it will reach the fluid.
Is there a drain plug.
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 01-11-2012, 02:06 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: How to remove window washer fluid from 2005 Silverado
No drain plug.
You could run the washers until dry; or the shop vac idea; or, pull the bottle off and turn it over.
What's the story with the sulfur smell? I'm not familiar with that happening...
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-11-2012, 02:23 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Man... it's a pain in the ass to get the bottle out. You won't be able to get a shop vac in it. The neck is super skinny and flat as it runs down the side of the battery then it balloons out into the tank. To remove it you have to remove the battery, then the battery tray, then it can come out. However, the pump is located at the bottom. If you pull the pump away from the bottle (it has a snap fitting at the top part) the bottom just fits inside the bottle with a seal, if you pull the pump the fluid will drain out. You should be able to get almost all of it out this way.
I had to pull mine out because it was leaking. Turns out the hard plastic hose had "cut itself" on the tabs on the bottle. It was a pain in the ass.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-11-2012, 02:43 PM   #4
remist17
remist17's Avatar
Originally Posted by Keith Seymore View Post
No drain plug.
K
I have no idea what the smell is from. I opened the bottle and started to pour in. I then start smelling this rotten smell. I thought my dog passed gas. Finished the bottle and then looked around. No dog, no kid.....
Smelled the bottle and it stunk. I had just bought it from Walmart. So god only knows what garbage is in the washer fluid. On the way to work today I tried to spray some and almost got sick from the smell./
Support the Troops.
Old 01-12-2012, 12:49 PM   #5
DjS71
My washer fluid smells the same, no idea but I'll follow just in case you figure it out.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 01-20-2012, 02:11 PM   #6
remist17
remist17's Avatar
well I emptied it all out and seems ok. I called the manufactor and they said it should not smell like that.
So Im out 3 dollars and will never use that product again. Went and bought rain ex.
Support the Troops.
Old 01-21-2012, 12:14 PM   #7
67ChevyRedneck
Just curious... how did you empty it?
Jesse James
Project "On a Dime"
Old 01-21-2012, 08:15 PM   #8
Daze57
Daze57's Avatar
best way is to pull the washer motor out (CAREFULLY)
Daze57 is offline   Reply With Quote
Old 01-25-2012, 12:46 AM   #9
gldevall
gldevall's Avatar
What brand was it? I surely do not want to buy any.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
