Old 01-11-2012, 04:54 PM   #1
lil_sahara450r
what size tires for 17x8 rim??
hey guys,
I'm about to order some new wheels for my truck soon and Im going with a 17x8 TT2. I would like to know what size tires and backspacing would work for my setup. I have a set of 2600 dominator bags, c notched, 2 inch drop blocks, and a set of 5 lug axles in the factory rear end in back and I will have a set of disk brakes from a 73-87, drop spindles, and drop springs in front. this is a SWB truck. and i HAVE used the search function with not much luck at all. any help would be greatly appreciated and pictures would be icing on the cake. Thanks guys!!!!
P.S. the fender lips in back were rolled in from the PO, i will be rolling them back out to put the strength back in the bedsides. the sides loose alot of strength with the lips rolled in and get floppy.
lil_sahara450r is offline   Reply With Quote
Old 01-11-2012, 05:24 PM   #2
forestb
forestb's Avatar
Re: what size tires for 17x8 rim??
All I know is that 275's will be to wide. I would guess around 255 would be a good width.
forestb is offline   Reply With Quote
Old 01-12-2012, 05:48 PM   #3
lil_sahara450r
thanks for the info! anyone else? i know alot of yall have 17's!!!
Old 01-12-2012, 06:00 PM   #4
Slow Build
Slow Build's Avatar
I saw this truck at C10 Kings Get Together this year. He had 17" wheels all around, 8" front & 9.5" rear. He was running 255/50s front and 275/50s rear.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-12-2012, 08:38 PM   #5
trelogix
trelogix's Avatar
I've got 255/55's on 17x8's on the rear, and 235/55's on 17x7's on the front. Both seem to fit very nice (my 66 is currently "in process"). I mocked everything up about a month ago and the rear tires fit with about 1 to 1.5 inches clear on either side of the tire. There's plenty of room in the front.
Steve
66 C10 Short Wide
51 1/2 ton (in storage waiting for 66 to be done)
Pickups N Panels Club - Dallas/Ft Worth
trelogix is offline   Reply With Quote
Old 01-12-2012, 09:05 PM   #6
Iron-Butt
454 club
Iron-Butt's Avatar
I run the 17 Impalla SS factory wheels and tire on all fours without any problems. about 20000 mile so far.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 01-13-2012, 11:06 AM   #7
lil_sahara450r
awesome info guys, keep em coming! iron butt, what size tires do you have on your impala rims?
Slow build: that is one of my favorite trucks! thanks for posting!
Old 01-13-2012, 11:44 AM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Im running 6-lug TT/ST's in 18'' on my '64. I have 275/40/18's all around which have a diameter of roughly 26.5''. They fit no problem. The backspace on my rims is 5.25'' and fits in the rear but hit the tubs in the bed. The centerbore is too small to fit over the axle hub in the rear but I used a .25'' spacer to clear.
The backspace works well in front with 5.5'' of drop and no rubs and about 1.25'' clearance above the tire to the inner fender.
You may have to get 2 different backspacings front/rear to get perfect fitment on the truck, especially once you have disc's up front.
Thought this info mite help as it's close to what you are considering.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-13-2012, 01:51 PM   #9
Baby Blue 66
The setup I am running is AM Racing Hopster, 17x8, 5x5, 4in backspacing, -11mm offset, tires are hankook ventus, fronts are 225/50r17, rears are 275/55r17. My truck is a short bed fleetside with a 3.5/5 drop, the rear tires are tucked far enough into the wheel wells that the truck has to be jacked up by the frame so the axle will drop down in order to get the wheel/tire out, they are really tight in the wheel wells, they don't rub, but it's really close.
Baby Blue 66 is offline   Reply With Quote
Old 01-13-2012, 03:50 PM   #10
lil_sahara450r
protrash: thanks for the info! from what you stated, i would need to order rims closer to ~4" backspacing instead of 5.25 to get the rims farther away from the tubs. thats good to know!
Baby blue 66: first off, that is one fine looking machine you got there. love the truck. I think I am going to follow your lead and order the rims with 4" backspacing and the sizes you recommended. Do the back tires ever rub if youre going up an incline at an angle, like when the axle is farther up on one side than the other (make sense?)?
Old 01-13-2012, 06:42 PM   #11
protrash64
protrash64's Avatar
Thats based on a 6-lug early axle, not the 70+ axles that were wider. FYI.
