Old 01-11-2012, 05:36 PM   #1
l79m20
292
Will the intake and exhaust manifold off a 250 cu inch motor work on a 292 cu inch? Am loooking at a 292 motor without and just wondering?
l79m20 is offline   Reply With Quote
Old 01-11-2012, 05:45 PM   #2
1963c-10
1963c-10's Avatar
Re: 292
Yes, the manifold will fit and work, but the exhaust size is smaller on the 230/250 manifold than it is on the 292 manifold.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-11-2012, 06:13 PM   #3
l79m20
Re: 292
Thanks for the response. Will that be an issue in the future or is the openings just slightly smaller?
Old 01-11-2012, 07:41 PM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 292
I always thought they had the same part number?
When I change mine on my '64 292 with a brand new one from Chevrolet, the exhaust fit just fine.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 01-11-2012, 08:13 PM   #5
gimmy 64
Re: 292
the outlet is larger on the 292 exhaust thats all
gimmy 64 is offline   Reply With Quote
Old 01-11-2012, 08:51 PM   #6
sigshooter
sigshooter's Avatar
Re: 292
the pickups use the same manifolds, only the dump trucks had the larger exhaust. I work in a salvage yard and have checked the interchange info.... I also just pulled the manifolds of a 64 1/2 ton 292 and put it on my 65 1/2 ton230.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 01-11-2012, 11:10 PM   #7
l79m20
Re: 292
Thank you all who replyed, guess I'll go ahead and get motor. Thanks again.
Old 01-11-2012, 11:57 PM   #8
pulltilbroke
pulltilbroke's Avatar
Re: 292
The 292 is a 2 1/2" dump with 3 bolts whereas the 194/215/230/250 is I believe 2 or 2 1/4" with 2 bolts
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 01-12-2012, 12:25 AM   #9
Wrenchbender Ret
Re: 292
The 1/2 to 1 tons had a 2 in outlet. The early ones had 2 bolts & the later (about 68) had 3 bolt flange. Either will work if you get the corresponding flange. The 1 1/2 & larger trucks used a 2 1/2 in. opening & points straight down. You will need somefabrication to use it.
Wrenchbender Ret is offline   Reply With Quote
Old 01-12-2012, 07:52 PM   #10
Heater63
Heater63's Avatar
Re: 292
And you have the option of hot rodding it with the Offy intake + Headers or Langdon Cast Iron headers like so many of us do. Some $$ but then you can run a modern 4bbl.
If you found a good 292, grab it. It's a good investment even if you don't use it. They are getting harder to find and are very popular still.
292 + TKO500
Heater63 is offline   Reply With Quote
