need some newbee help Small Block to Big Block swap
Hey guys I'm sure this has been covered before but I will ask anyway. I did a search and really didnt find what I was looking for.
My 70 2wd has a small block currently... I got a smoking deal on a 454 built big block. I know the motor mounts and radiator will have to be changed. Can I use the 396 motor mounts or??? Is there any cross member changes ect.. Can I buy a conversion kit? Thanks for the help guys!!
1970 c10 2wd th400 and a stock 350...BBC soon to follow ~ Mild Built 454 Sitting in my Garage 2011 Silverado Crew Cab 6.2L Fast Motorsports Performance Tune 20 inch KMCs Nitto Terra Grapplers BDS Leveling Kit |
My Carbon Footprint
Re: need some newbee help Small Block to Big Block swap
I went from a 250/sm465 to a 460/M-22. Mine about fell in and I had the correct stands. I would thing yours will be just about as easy except for small stuff. I'm guessing trans mount will be just about the only thing to play with and that a small one.
Actually, in looking at your sig, you already have a TH400. Seems like mine had a few different holes on the frame rails. You can use the X member you already have. I just don't know if you will have to relocate it. I would guess not. |
I'm hoping it will be almost drop in... I just need to find out what mounts I need/can use. the big block is a 79 block.
My Carbon Footprint
Block doesn't matter. You just need the correct stands for these year trucks. They are not cheap used.
by stands are you talking about motor mounts?
My Carbon Footprint
To me, the mounts are what attach to the block and the stands are what attach to the frame. The mounts then attach to the stands.
gotcha so another stupid question. Is the mount that goes to the block the same no matter what the block size? or can those be different?
My Carbon Footprint
I "believe" it doesn't matter about block size rather year of the project. Some of these trucks use a clam shell on the frame and you need the correct mount. I know my '68 used a stand and a different mount because a big bolt went up through the inside of the stand and screwed into the mount. A PITA at times. I think the later trucks like mabye a '71 or '72 have the clam shell on the frame and a mount where a bolt runs though both mounts and has a nut on the end like a Camaro and most other later model rigs......if that makes sense.
You can use 68-71 stands
![]() 72 ![]() tubular aftermarket ![]() BB TH400 linkage ![]() 4 core radiator
Pancho 69 c/10 step side 454/400 with 3.07 |
Eat, Sleep, Drive a Chevy
dont want to bust your bubble... dont run the turbo 350 transnission behind that big block, it wont last. you need to find a 400 turbo for it. This will also require a drive shaft yoke change.
Also factory used the big hump floor for TH400, but I have seen guys put them in the small hump floor, its a little tighter good luck!
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
My Carbon Footprint
Look at his signature. He currently has a TH400 behind the 350 sbc.
Nice try Mr. "bubble buster meany"!! lol |
opps, but hey thats a good thing!
#13 |
My Carbon Footprint
One less part to get. You are right about the TH350.....especially behind a 454.
Cool avatar |
#14 |
Here is what is currently on the truck....
Are these the correct stands then? ![]() ![]() ![]() Posted via Mobile Device
#15 |
Not the right stands but you can still use them, I did when I put a big block in my small block truck.
#16 |
My Carbon Footprint
They are the correct stands for a SBC.
Randy, did you run into any issues you had to overcome? Are the SBC stands taller? |
#17 |
Do u have headers randy...how did you overcome the sixe difference?
#18 |
The only thing I remember is the headers were real close to the stands. When I did the swap I didn't know there were different stands for big blocks (ignorance is bliss), I just stuck 'er in and bolted 'er up. Drove it like that for 18 years.
#19 |
I had Hooker Super comp headers. As I said in the last post, the headers were real close to the stands. When I took the truck apart for the frame off rebuild there was a dent in the #1 header tube where it was hitting on the engine stand. These were pretty small tube headers (1 7/8ths I think), the headers I have now would not have fit with the small block stands (I bought big block stands).
