Old 01-11-2012, 10:07 PM   #1
cobra
1970 gmc Ingition switch installation
All,
I am newbee to the forum and this is my first time posting.
I am having a heck of a time installing a new ignition switch into my restoration project. I completly restored my 70' and am now in the process of putting it all back together.
For the life of me, I cannot get the tumbler to stay in the newly installed switch.
The Switch is plugged into the harness, spacer backs up to the back of the dash, I installed the bezel (remembering that the tumbler came out first).
But I cannot put the tumbler in and remove the key to finish the installation.
I need your guidance.
Thank you in advance
cobra is offline   Reply With Quote
Old 01-12-2012, 12:43 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1970 gmc Ingition switch installation
First off, .. to the board...
First you need to insert a screwdriver into the new switch and make sure it is turned to the left as far as it will go...DO NOT FORCE IT!!! It should turn fairly easy.After you are satisfied it is all the way to the left insert the lock cylinder with the small hole at about 1 o'clock position and push in on the cylinder. You should feel a little spring pressure on it. If the end of the cylinder doesn't drop down into the slot at the bottom of the switch gently turn it back and forth until it does. Once you have it in push in on the key and turn it to the right until it clicks in.
LockDoc
Leon
Old 01-12-2012, 07:32 AM   #3
cobra
LockDoc, thank you.
I will give it a shot today after work.
Just one more question:
When I insert the cylinder (hole in the 1:00 position), that is with the key installed, correct?
And no need to try to depress that little button or anything on reassembly only disassembly?
Again, thank you for your help and have a great day.
Old 01-12-2012, 07:55 PM   #4
LockDoc
LockDoc's Avatar
Originally Posted by cobra View Post
LockDoc, thank you.
Yes, with the key in.
No need to push it in for assembly
No problem.
LockDoc
Leon
Old 01-12-2012, 10:50 PM   #5
cobra
Lockdoc,
Spot on!
Went right in, 1st shot, done in 10 seconds.
Thank you very much!
Old 01-12-2012, 10:54 PM   #6
LockDoc
LockDoc's Avatar
Lockdoc,
Spot on!
Glad to hear you got it whipped.... Good job!
LockDoc
Leon
