Slow Windshield Wipers, Help!
I bought a new 86 chevy, and the windshield wipers are SLOW, even when switched on high... Can someone tell me how you fix this??
-Samuel "Knowledge Is Power" |
Re: Slow Windshield Wipers, Help!
It may be possible that your switch may not be turning on the highs or a ground issue may be present
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Where would the ground be specifically for the wipers?
There is. Ground strap on the wiper motor itself, if you have an alligator clip you can ground it to the motor and if there is a change then you have your culprit. What year truck do you have?
I have a 1986 Chevrolet
![]() Posted via Mobile Device
Ok same year as mine well I just replaced the wiper switch in mine since the old one had moisture damage on the contacts
Why are my windows rolling down so slow???
I have an 86 that has power windows. When I roll them down they move SO SLOW! What could be the problem?
Re: Why are my windows rolling down so slow???
it could be worn out brushes in the motors
or corrosion in the switches or mechanically binding
On a budget like Fred Sanford
Mine were like that, the colder it got the slower they moved. The motors in mine were shot. Put new motors in and lubed the tracks.....good as new now.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
