Old 01-11-2012, 11:51 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Bagged - Key to Low Ride Height
Hey guys,
I will be bagging my truck soon and need something splained to me. I don't want the truck to lay rockers, I want it low though. More importantly, I want the actual ride height to be low.
Take the below truck (BIG AL's)
I want the truck to ride at this height, not be aired out at this height. Does that make sense? In other words, I don't want the truck to have to ride at a height that doesn't look as good as the below truck does.
Now I have no idea if this is Big Al's aired out height or not. But what would it take to be able to ride at this height? I don't want to go to crazy with the frame mods, and I know I most likely will have to remove the inner fenders. I plan on running 18x8 and 20x12 wheels.
Thanks for all the help!
BTW Great looking truck big al
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 01-12-2012, 12:03 AM   #2
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Re: Bagged - Key to Low Ride Height
Here is the truck as it sits now... No notch no nothing.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 01-12-2012, 12:43 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
We make a Mild Dropmember kit that will give you that ride height.... but doesn't lay the frame on the ground when deflated.
You will have to mod the front inner fenders and also raise the bed floor about 4 inches.
If you would like more information, shoot me your number in a PM and I can give you a call to dicuss all the options.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-12-2012, 06:48 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Big Al's truck is air'd out in that picture.
The problem is the stock front crossmember.
They are too close to the ground to drive them that way.
Give Porterbuilt a call.
He has exactly what you need to accomplish the ride height you want.
Keith
Convert to disc brakes.
Old 01-12-2012, 09:26 AM   #5
Rochlow
Yes, Nate is the man!! In a month I will being getting a new truck and one of the goals is to be able to drive the truck extremely low. Nate helped me come up with a plan to do that.
Rochlow is offline   Reply With Quote
Old 01-12-2012, 09:48 AM   #6
shawno72
C/10 junkie
shawno72's Avatar
Subscribed.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-12-2012, 12:51 PM   #7
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Damn... Had no idea I would need a dropmember... I thought most of my work would be in the rear, but you're right, my front member right now is about 5 inches off the ground...
Anyone know what Big Al's truck looks like a ride height?
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 01-12-2012, 12:53 PM   #8
chevjayfsd
Project 7dos
chevjayfsd's Avatar
I've PMed him and requested that he post pics of his ride height here.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 01-12-2012, 01:17 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
I could be wrong, but from experience I would say that the pic you posted of Al's truck is setting on the inner wheel wells in the front and then bottomed out on the notch in the rear.
There could be a little more room gained in the front by modifying the inner wheel wells... but you will need to keep an eye on lower control arm to ground clearance.
You could drive the truck 2" higher than that and would probably only rub on occasion with normal driving (normal means like a responsible adult... not sure if that's how everybody defines it).
If you want to drive at that height.... there's a lot of work to do.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-12-2012, 01:22 PM   #10
shawno72
C/10 junkie
shawno72's Avatar
Nate
How much $$ are we talkin to ride that low?? The work part is easy it's the money for me.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-12-2012, 01:51 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Story of my life!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-12-2012, 02:30 PM   #12
big_al_71
big_al_71's Avatar
Nate
Nate is 100% right ..
In that picture the truck is completely aired out and it is on the bumpstops front and rear. My truck has tubular arms in the front and a small cnoth in the rear. In order to go lower the next step would be a drop member, no inner fenders and a step notch in the rear.
First picture is aired out next two picts are at a safe ride height technically I could go about an inch lower to drive it but as already mentione the front cross member is really low. I hope this helps....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-12-2012, 02:32 PM   #13
big_al_71
big_al_71's Avatar
In the last picture the front is at it's limits pretty much it has maybe about 1 1/2 travel the back could go lower about 2 inches and still be able to drive it.
Old 01-12-2012, 02:50 PM   #14
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Awesome! Thanks Big Al, beautiful truck.
Big Al's ride height is just right where I want to be.... Although, he has 20's in the front, so i need to figure out how that will affect me...
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 01-12-2012, 02:58 PM   #15
big_al_71
big_al_71's Avatar
Thank you!!!!
I can take more pictures for you if you need me to...
Old 01-12-2012, 02:59 PM   #16
brandy hickman
brandy hickman's Avatar
Big Al. Where is your tank and air compressors located? I do not want to place them behind my rear seat. Kinda tight on room? Any pics or advice would be appreciated! I am nervous about finally writing a check for all the parts
brandy hickman is offline   Reply With Quote
Old 01-12-2012, 03:01 PM   #17
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Another question... What advantages are gained when using tubular arms vs. stock arms? I ask this because, if my wheel wells are the limiting factor, and I want to be right at where Big Al is aired out and at ride height, why would I spend the coin on the tubular arms, when they aren't the limiting factor?
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 01-12-2012, 03:03 PM   #18
big_al_71
big_al_71's Avatar
My valves/tank & compressor are under the bed in front of the right rear tire...
Checkout this picture it kind of gives you an idea.
Old 01-12-2012, 03:09 PM   #19
big_al_71
big_al_71's Avatar
I bought them because of several reasons:
Better looking, lighter and I beleive stronger...
Old 01-12-2012, 03:19 PM   #20
tubbedII
needs more $$$
tubbedII's Avatar
You're right...but if you want to drive at Al's aired out height, you're going to have to lose your wells and go with the dm/tubulars for the added drop and still keep some suspension travel. (look at 67Cheby's Slosh Tubz for a bolt in fix for the wells).
Unfortunately, this won't work with the blazer since it has the rocker boxes in that location. I've been trying to think of something too to get the tank out from behind my seat, but coming up short. My only plan that's somewhat feasable right now is getting 2 3 gallon tanks and mounting them on the sides of the gas tank under the rear, but they may show from the side due to the body coming back up towards the bumper.
1970 2wd Blazer
Old 01-12-2012, 03:49 PM   #21
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Cool Re: Bagged - Key to Low Ride Height
Well that's the thing... In hearing how much $$ it's going to take to ride at Al's aired out height, I'm just going to mimick his height. So to get a ride height like Al's RIDE HEIGHT, the tubulars aren't required? Correct? Sure they are a nice addition, and I will get them one day, but for now, if I can, I will just stick with the stock A arms. That way it'll give me an excuse to work on it later!
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 01-12-2012, 04:05 PM   #22
jimmydean
jimmydean's Avatar
You can use the dropmember with your stock arms to get lower than Al's. That is a great looking truck, Al.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-12-2012, 04:09 PM   #23
blazer2007
I was to understand that some tubular arms like cpp [I think] would give you a inch or alittle less when aried out
blazer2007 is offline   Reply With Quote
Old 01-12-2012, 04:17 PM   #24
shawno72
C/10 junkie
shawno72's Avatar
Here is a good deal on a set of lower control arms.
http://www.ebay.com/itm/300648815916...84.m1438.l2649
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-12-2012, 04:44 PM   #25
502ms
502ms's Avatar
I'd say definitely do the drop member or Z the front and the c-notch to the rear. In either case, money will be spent...but I will say it pays off
Best Regards,
Leon M.
502ms is offline   Reply With Quote
