Old 01-12-2012, 12:38 AM   #1
58Hound
49 3600 - S-10 Swap - 8 Lug Wheels
I have a 3/4 ton 1949 Chevy pickup and I am considering an S-10 swap. I like the original 8 lug wheels and want to keep them.
Is it possible to switch the front wheels from the 5 lug pattern to an 8 lug pattern? If so, what would it take?
58Hound is offline   Reply With Quote
Old 01-12-2012, 02:56 AM   #2
sirwilliam
Re: 49 3600 - S-10 Swap - 8 Lug Wheels
easy way... im sure you could find adapters
sirwilliam is offline   Reply With Quote
Old 01-12-2012, 10:52 PM   #3
BlueJeep
BlueJeep's Avatar
I've seen it done before on a Jeep. Adapters to go from 5 on 4.75 to 8 on 6.5. It's obvious, but the brakes and wheel bearings will remain s10, so don't expect it to haul and perform like a 3/4 ton.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-13-2012, 12:11 AM   #4
mr48chev
mr48chev's Avatar
You might try these guys for adapters. http://adaptitusa.com/index.aspx They don't show five to eight lug adapters because I would imagine that there is very little call for them. They do say that they do custom orders.
They may snicker a bit as it won't be a common request but my guess is that it isn't a difficult request when they are already set up to do both bolt patterns on their adapters.
I think a lot of the guys with the S-10 chassis in these trucks are using a 1-1/2 inch spacer to space the wheels out in the wheel opening anyhow as the S-10 track is narrower than the AD truck's track. That might depend on how deep your rims are though.
