Old 01-12-2012, 08:28 AM   #1
nachodog2
Hell yeah!!!
nachodog2's Avatar
Wiring question
Can you run dual compressors from a hot lead on your fuse box or will this run too much current? Or should I play it safe and run directly off the battery? Relays are definitely going in.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 01-12-2012, 08:57 AM   #2
PAPA KENT
PAPA KENT's Avatar
Re: Wiring question
myself i would run your leads off of the battery for sure.the factory wiring in your truck was'nt designed for that kind of current.thats only my opionin.
PAPA KENT is offline   Reply With Quote
Old 01-12-2012, 12:49 PM   #3
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: Wiring question
Thanx papa, I actually have a new aftermarket wiring kit in there. But like you said and I suspected, I think I will run them off the battery which the diagrams show in order to not run the current thru the fuse box.
