Old 01-12-2012, 09:02 AM   #1
1959 Apache 3600
1959 Apache 3600's Avatar
1/2 ton frame -vs- 3/4 ton frame
Is there a frame difference between the 1/2 and 3/4 frames such as thickness and rigidity or is the difference just in the suspension?
I've got a 3/4 and am wondering if I need to box it while I have most of it apart.
Thanks!
1959 Apache 3600 is offline   Reply With Quote
Old 01-12-2012, 09:26 AM   #2
Larry Lindley
Re: 1/2 ton frame -vs- 3/4 ton frame
that is up to you, Ive ran them both ways,full box or part.
Larry Lindley is offline   Reply With Quote
Old 01-12-2012, 09:32 AM   #3
Larry Lindley
what are you using the truck for?Drive train change?never had any problem with mine.someone will chime in .there are alot of good views on this forum.
Old 01-12-2012, 11:26 AM   #4
mknittle
mknittle's Avatar
I would box it now these frames are pretty flexy .
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-12-2012, 01:57 PM   #5
OrrieG
OrrieG's Avatar
The literature link in my signatue has a page that shows all the frame specs.
The frames were designed to be flexible and straighten out because back then they were used to cross fields, ditches, streams, and go off road. I have had mine with the axles at opposite extremes with the cab and bed twisted. I once popped the weld were the A pillar meets the cab and thought for sure I was going to blow out the windshield.
If you are upgrading the suspension and plan on just driving it on the street and highway then boxing is an option to strengthen the connection points. I have not boxed any of my frame, or welded on any of the suspension, engine, etc. mounts and have not had any problems.
OrrieG is offline   Reply With Quote
Old 01-12-2012, 03:30 PM   #6
_Ogre
_Ogre's Avatar
not sure what the difference is, but i know they are different.
you can't get a mustII for a 3/4 or 1 ton frame.
a factory assembly manual will tell you everything you need to know
they are also handy for reassembling your truck, a worthy $29 purchase
it will flex, i like the look of a boxed frame.
i also welded all 3000+ holes in my frame (slight exaggeration, maybe)
shop air compressor timer
Old 01-12-2012, 05:18 PM   #7
1959 Apache 3600
Great! Thanks for the replies.
I'm moving up to a big block C454 and TH400. I also plan on flatbedding and putting dualies on the rear end.
Old 01-12-2012, 06:52 PM   #8
MrTucker
MrTucker's Avatar
the only difference is the length. I dont think any 3/4 tons were made in short beds.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 01-12-2012, 07:10 PM   #9
Larry Lindley
with the drive train up grade I would box frame.
Old 01-12-2012, 08:21 PM   #10
mknittle
mknittle's Avatar
I agree for off road I would not box it my 42 willys jeep is not boxed and flexes better than the boxed ones.
Mark
My GMC build.
Old 01-12-2012, 09:20 PM   #11
OrrieG
OrrieG's Avatar
Those were the other rigs I learned to drive and wrench on. Our favorite was a M38A1 with PTO winch. They were the ones used for Communications and came with 24 volt electrical system, sealed so you could literally run water up to the bottom of the windshield. Worked really good in Western Oregon, were its wet all the time. Thing would climb a tree in low range. Back then you could get them at govt auctions for a couple hundred dollars, slap a paint job, chrome rims and a roll bar on them and sell for $600.
