install instructions for swing away spare tire carrier?
I just got mine in parts and was seeing if anyone had original install instructions or if someone could just tell me how.
Posted via Mobile Device |
SKINNY TIRES RULE!
Re: install instructions for swing away spare tire carrier?
I've never seen any instructions, but I whould think it is fairly straight forward. If you hold it up to the truck, it should fit in a certain spot. Mark where to drill the holes and then put the brackets up inside the bed for the threads. Make sure you put the tailgate attachment on when you're holding it up to the truck so you know it is in the right place.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Well the tire carrier i got doesnt have the brackets. I assume that this is going to be something hard to find as 1. its aftermarket and 2. people dont usually sell one without the other, except for in my case. I think i am going to have to fab some up unless you have heard of somewhere to just buy the brackets themselves.
One of the First
![]() Join Date: Jan 2000
Here ya go:
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Thanks! now i just need to find the inner brackets.
SKINNY TIRES RULE!
that's the hard part. Several years ago, I loaned a set brackets (I no longer have them) to a board member so he could have a set reproduced. The costs were too $$ because the brackets both had compound angles. In the end, he found a set.
I'd suggest becoming a subscribing member and posting a "wanted to buy" thread.
urban fourwheelin
They would be easy to make. I have two Swing aways that I bought some years ago one with and one without brackets. I found a extra set of brackets later. I could probably produce a set by hand in a 2-4 hours.....Which might make them cost prohibitive to most people as you could buy a complete one for the same money or less.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
#8 | |
urban fourwheelin
straight time and materials. $100 to $200 bucks. Hand made stuff @ shop rate is expensive.
Sounds good. Ill keep it in mind for a back up plan if i cant locate them somewhere else. Thanks.
