Old 01-12-2012, 11:41 AM   #1
dcasalena
dcasalena's Avatar
Seeking grounding strap/cable advice
Planning to replace all engine and body grounds.
Any advice on using grounding strap vs. cable? Gauge?
Where's the best place to buy regarding cost?
I can buy in bulk and crimp on my own terminals if that's more cost effective, so what length to do the whole truck?
dcasalena is offline   Reply With Quote
Old 01-12-2012, 12:19 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Seeking grounding strap/cable advice
Interested in this also.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-12-2012, 12:53 PM   #3
snj8198
snj8198's Avatar
hi,
Do a search in the electrical section. I know there was a couple of informative threads going early last year. I referenced them when I was installing my new wiring harness as I too replaced all the grounds. I used the premade braided ground straps by IDIDIT (10inch i think) found at my local auto store. They were way too long so I cut them in half and just crimped on a new end on each. They worked very well and were about $5 each iirc.
Thinking out load:
bed-frame
bed-cab (not sure if necessary, i didn't)
cab-frame
firewall-motor
motor-frame
both inner fenders-frame
core support-frame (i did this because i ground all my lights and some accessories here)
battery-motor
battery-frame
Not all of this is technically correct i dont think but that's what I did. My truck is a daily driver, not a showy truck so quality of material may differ from others.
Hope this helps ya a little bud.
-steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-12-2012, 01:37 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I bought my ground straps at local auto parts store -I think O'Reilly's. No need to go crazy with the size just as long as you can reach the place you want to ground.
The reason we use more than what they originally had was because of rust and road grime keeping the bolts from making good grounding contact.
I placed one under the back of the bed to the frame.
One under the back of cab to frame.
Rear of motor to cab.
New battery ground cable to engine and just for kicks another strap from engine to frame.
Lastly, I used one from radiator support to battery ground. The horn and regulator on the radiator support on my truck use a ground and I wanted to make sure these were covered.
68gmsee is offline   Reply With Quote
Old 01-12-2012, 01:54 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
I picked up a ground wire kit for a camaro off ebay for about 11 bucks. It came with 5 wires and new bolts.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-12-2012, 02:02 PM   #6
Kurt L
Kurt L's Avatar
dumb question not really but will all that grounding your talking bout help with less engine noise in your stereo and cb radio? i've got condensers on my alternator and one on the hot wire from cb to battery. helped out alot but still pickup noise i belive from the electric fuel pump.
Kurt L is offline   Reply With Quote
Old 01-12-2012, 07:51 PM   #7
dcasalena
dcasalena's Avatar
I've tried my 2 local auto supply shops and neither carry ground straps or cables beyond battery to engine grounds.
Thanks for what's come across so far, but I'm looking for an online strap/cable source if there is one. Off to check out the thread referenced in #3.
Thanks guys.
Old 01-12-2012, 08:25 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
A little more $ than what I remember, but here's the one on ebay I was talking about: 69 Camaro ground straps
Really though, this is just wire from place to place all around the vehicle. It doesn't have to be anything fancy. I don't see any reason you can't just use some 10 gauge wire cut to fit with the ends you need.
1970 2wd Blazer
Old 01-12-2012, 08:41 PM   #9
70cst
70cst's Avatar
Maybe this will help a little ...
http://67-72chevytrucks.com/vboard/s....php?p=4502849
http://67-72chevytrucks.com/vboard/s....php?p=1726072
http://67-72chevytrucks.com/vboard/s....php?p=4204599
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-12-2012, 09:00 PM   #10
snj8198
snj8198's Avatar
Thanks 70cst, I referenced those myself when I did my wiring job.
Steve
Old 01-12-2012, 10:14 PM   #11
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
For whatever it's worth, I had a ton of left over batter cables which are super thick gauge. I used it on my race car which is a subframe car. I grounded the block to the frame front and back and then grounded both frames. You do this so you have a solid circuit for your ignition and starter....etc. Remember that most motor mounts have a rubber spacer which doesn't conduct electricity too well.
prostreetC-10 is offline   Reply With Quote
