01-12-2012, 12:52 PM | #1 |
99 ECSB W/4L80 shifting.... weird...
Got a '99 2500 ESCB with 6.0/4L80E w/70K
The last month or so, i've notived that, especially when its cold, it hangs out in gear longer then it used to. Maybe just time for a filter change? (no lift = nightmare!) What do you guys think? |
01-12-2012, 07:10 PM | #2 |
Re: 99 ECSB W/4L80 shifting.... weird...
Sounds normal...........
2-3, 3-4 Shift Characteristics During Cold Weather Operation on 4L60-E or 4L80-E Transmission Transmission operation during cold weather has been revised on these vehicles to provide faster engine warm-up and improved heater performance. During initial key-up, if intake air temperature (IAT) is less than 32°F, 2-3 and 3-4 upshift speeds will be affected as detailed below. 2-3 Upshift ^ If the throttle position (TP) is less than 37 percent, the 2-3 upshift will take place at a minimum speed of 32 mph. ^ If the TP is above 37 percent, the shifts will divert back to the normal shift pattern. 3-4 Upshift ^ If the throttle position (TP) is less than 37 percent, the 3-4 upshift will take place at a minimum speed of 47 mph. ^ If the TP is above 37 percent, the shifts will divert back to the normal shift pattern. TCC Operation If the transmission fluid temperature is less than 62.6°F, torque converter clutch (TCC) operation will not occur until the transmission fluid temperature is greater than 68°F. When the engine coolant temperature (ECT) reaches 171 °F, 2-3 and 3-4 upshifts will divert back to the normal shift patterns. If you getting a harsh 1-2 shift............There is a different PCM calibration for 99 models that deal with this specific problem.......... |
01-12-2012, 08:37 PM | #3 |
Wow, thats way more than i expected. Also, its awesome. Thank you.
01-13-2012, 02:33 AM | #4 |
Wow! I never knew about that. Great info Clinebarger!
2006 Silverado 2500 HD |
01-13-2012, 08:42 AM | #5 |
Yup, I bought my truck used in 2005 and I thought there was something wrong with it too (TC wouldn't lock on interstate) the first winter I owned it. This morning was really the first cold morning I've run the truck and it was doing the same as described above, holding onto shifts longer.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
