Old 01-12-2012, 01:08 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Another Pressure Switch Question...?
I may be making this a little more complicated than it is...
I am running two comp's, two 3 gal tanks with two ports, each. Also a simple 4-switch manual paddle valve set up. One pressure switch....
My questions is, where would be the best place to put the pressure switch in the system to get correct pressure readings? Should I run it off a "t" in front of one of the tanks?
Here's a pic with a generic illustration ;P of how I'm routing my lines. Compressors are mounted at the rear of the chassis... I "t'd" the compressors together just before the tanks, so that if one fails...
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 01-12-2012, 04:37 PM   #2
dv8customs
dv8customs's Avatar
Re: Another Pressure Switch Question...?
T it in on the crossmember between the tanks.
dv8customs is offline   Reply With Quote
Old 01-12-2012, 05:58 PM   #3
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Easy enough, thanks DV8
77' Chevy SB
5.3/4l60e combo
