Old 01-12-2012, 02:01 PM   #1
joe1966
Question Still need halp :/
i Have a 1966 chevy c10. 350 small block. hei distributor. 4 bolt main. i am still either having wiring problems or a distributor problem.. and i took a couple plug wires off the other day and i forgot were they went. how do u number the distributor? but i could care less about the plug wires i just need to get it running. anybody have any ideas? it turns over but wont fire. i put gas in the carb and still nothing. :/. i am no the wiring type of guy. i can do everything but wiring. i meen i can do a little bit but need help. wont start just turns over. is it a wiring problem or a distributor problem? helpp
joe1966 is offline   Reply With Quote
Old 01-12-2012, 02:42 PM   #2
brokenspoke
brokenspoke's Avatar
Re: Still need halp :/
18436572 is firing order
brokenspoke is offline   Reply With Quote
Old 01-12-2012, 03:40 PM   #3
losthope
losthope's Avatar
First off since you pulled the plug wires and forgot where they went go ahead and pull them all off, Im assuming you can crank the motor over with the key, so if thats the case pull the #1 spark plug and wad up a small piece of paper towel so it plugs up the spark plug hole,have someone bump the key a few times while you watch the paper wad until it shoots out of the hole(might have to do this a couple times to get it right) once your confident you seen it shoot out , you should be on compression stroke the take a socket and breaker bar and turn the motor over by the crank nut untill you line the timing tab pointer up with the "TDC" mark on your harmonic balancer(when the paper shoots out the timing mark should be close to coming around to the timing tab make sure when bumpping the key you dont over shoot the timing mark past the timing tab)....pop the cap off the distributor and see where the rotor is pointing,if its not pointing at where the #1 spark wire post on the cap(see diagram to where #1 is at,or sometimes #1 is marked on the cap inside or outside) then loosen the hold down for the distributor and reset the distributor in so the rotor is facing where #1 should be then snug the hold down up to where you still can move the distributor by hand. Chevy 350 engines are notorious ,if they sat for any length of time without being started to foul the spark plugs and they wont fire,so since you have all the wires off it would be best to buy new spark plugs and make sure they are gapped right with a gapping tool(not always gapped right from out the box)and replace your spark plugs.....then wire the spark plug wires as showed in the picture(see diagram)...then pull the wire that goes to your "HEI" distributor and take a test light probe and have someone turn the key all the way to "START" and make sure theres power, then have them turn it to just the "ON" position and make sure theres power...if so then rehook up the wire(If you dont have power then you need to find out why).....This should make your engine start...you might have to turn the distributor back and forth a little to get it to fire but not much...once your engine starts then use a timing gun and time your engine and the tighten down the distributor.....
If it still dont fire you will want to make sure the coil in the cap of the "HEI" is good and your getting spark from the distributor down to thee spark plugs....
Hope this Helps.......
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 01-12-2012, 03:47 PM   #4
blackmopar
^^ yup
blackmopar is offline   Reply With Quote
Old 01-12-2012, 04:06 PM   #5
1963c-10
1963c-10's Avatar
My question is ....how was it running prior to you getting into it? Did it run fine prior or were you trying to fix something?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-12-2012, 08:41 PM   #6
joe1966
It ran awesome! very fast great running truck. and then 1 day it would run bad like it had a dirty plug and then it would die. now i have no more truck :/
Old 01-13-2012, 11:04 AM   #7
1963c-10
1963c-10's Avatar
Did you get the plugs back in the proper sequence now? Hows it running?
Old 02-01-2012, 06:30 PM   #8
joe1966
I got it going. Pretty much rewired thw whole truck.; runs like new again!
help. chevy
